Low range light
Old Mar 31, 2009 | 02:22 AM
pitmanr2003's Avatar
pitmanr2003
Low range light
Ok I just got my 97 eddie bauer. I was trying out the 4wd. When I select 4awd i can hear a noise like it is changing same when i go 4h. When i go 4l i hear nothing. Just wandering how I can tell it is in 4l. I know there is a low range light, but it doesnt come on only 4x4. When does the low range light come on. When in 4 low it sounds and feels like its in 4l. But how would I know.
Old Mar 31, 2009 | 09:25 AM
alloro's Avatar
alloro
Were you stopped and in neutral when you switched to 4L? If you're not, it won't shift into 4L.
Old Mar 31, 2009 | 09:39 AM
pitmanr2003
i was stopped and in park. it went to 4h maybe i will try neutral. It said 4x4. In manual it says only if low range is available will low range light come on. is that a seperate option from 4wd.
Old Mar 31, 2009 | 11:35 AM
alwaysfords41's Avatar
alwaysfords41
You can't get into 4L while in park. You need to go into N. Low was not available to you becuase you didn't follow the procedure. Do over!
Old Mar 31, 2009 | 12:55 PM
pitrow's Avatar
pitrow
low range is not a separate option. If you have 4wd you have it. Like everyone else says follow the proper procedure and it will work. There will be a "low range" light on the dash, and you will DEFINITELY notice it when you start driving.
Old Mar 31, 2009 | 04:06 PM
pitmanr2003
i got it to work. has to be neutral
Old Mar 31, 2009 | 06:47 PM
alloro's Avatar
alloro
Yah think!
mike L
Feb 23, 2006 08:53 AM
jlv3901
1997 - 2003 F150
Dec 22, 2005 06:34 PM
pcguy760
Feb 9, 2005 06:03 AM
red bud
1978 - 1996 Big Bronco
Jul 23, 2003 11:09 AM
