Wheel Selection/Backspacing Help
Old Mar 30, 2009 | 03:37 PM
Lance Hogan's Avatar
Lance Hogan
I am trying to finish up my 1955 F100 and am to the wheel/tire stage. I want to make sure that I get the correct wheels to fit my application and would like to run my selection by you guys. Here goes…
I have a Heidt’s Mustang II IFS (power steering) installed up front with 5x4.5 bolt pattern. In the rear, I installed a 1967 Ford 9” truck rear end (61 ¼”) with stock fenders (11” of clearance). I am looking to purchase 15”x7 (front) and 15x8.5” (rear) American Racing wheels, both having 3 ¾ backspacing. My tire dimensions are 215/65/15 up front and 225/70/15 in the rear. Do you think I will have enough space? Any thoughts or suggestions would be appreciated.<O
<O
Lance<O
Old Mar 30, 2009 | 04:17 PM
rockher_man's Avatar
rockher_man
Thumbs up tire & wheel deal...
I'm tryin' to figure out mine too on my '56......with real wires...
...lookig at 15 x 8's all around & hopin' for maybe 235/70/15 with 3 1/2
to 3 3/4 back-space...
Gonna run TCI MII IFS up front & No-Limit 4-Link out back on a '70 9"
ALL on air-ride...
Kinda frustratin' ain't it......
Sounds like you'll have plenty f room though......
Old Mar 30, 2009 | 07:28 PM
homade's Avatar
homade
Lance, go to Early Wheel and they have a diagram on how to figure the back space you need or you can call and talk to jason the owner, he's a good guy.
Old Mar 30, 2009 | 07:34 PM
3golfjack's Avatar
3golfjack
<O
Lance<O
I have a Heidts Mustang II IFS on my 56 I am using 15x7 Cragar rims on the front and had the same question you have. I sent Heidts a Email just yesterday asking them what they recommend for backspacing for this setup and they recommended 3 3/4" Backspace.This is for the front
Old Mar 30, 2009 | 07:57 PM
going slow's Avatar
going slow
with 225's on back you should be fine....one thing you could do is go to your local tire shop and grab a throw away or (scrap) tire most places give them away ( i know at your shop we do) but then you can get an idea of how that tire will fit in there....i know they make a tool you can bolt to your hub and then slide a tire over it and you can adjust it to find your backspacing....AutoWare Technologies, LLC, Makers of SoftWheels ....is the site of that tool....good luck
Old Mar 30, 2009 | 09:25 PM
Lance Hogan
Guys,
Thank you for the help. I checked out Early Wheel Company as suggested by Homade discovering a nice chart that helped me with my measurements. If I followed the site information correctly, I believe a 15x8.5 wheel with 3 ¾“ backspacing will be a little too tight. With the stock fenders (11”) and a 1967 Ford F100 9” rear end, I have roughly 5 ¾” backspacing leaving 2” from the rim to the bed panel. On the other side, I would have 4 ¾“ leaving ½“ (2 + 3 ¾ + 4 ¾ = 10 ½ ) from the rim to the fender. With the advised 1” clearance for tire bulge an 15 x 8.5 wheel wouldn’t fit. I am not a mathematician, but I think my numbers add up. On the front, I will go with the 15x7 wheel as Heidt’s suggested (thanks 3golfjack).
<OAgain, thanks for all the help as I would not know what to do without it.
<O
Respectfully,
<O
Lance<O</O
Old Mar 30, 2009 | 10:46 PM
sdetweil's Avatar
sdetweil
Go here, http://www.billetwheel.com/downloads...9_03_24_09.pdf
page 12 is the measurement chart, need the body on, fenders on..
Sam
LAbronc
1978 - 1996 Big Bronco
May 22, 2014 10:15 AM
aldrowsboy
May 7, 2013 06:31 PM
Lance Hogan
Jul 15, 2012 06:40 AM
ThaFrenchy
Projects
Feb 22, 2010 07:26 PM
avgjoe
Dec 28, 2004 11:42 PM
