Siren turbo
Old Mar 30, 2009 | 09:35 AM
muddiejeep's Avatar
muddiejeep
Siren turbo
My truck make a faint siren sound above 7psi of boost. It gets 23 psi at full throttle, no more smoke or less smoke than usual, and same as usual EGTs.
When i heard it, I thought it was a loose boot. Under the turbo one orange boot was sucked in a little so I put it back on and the sound is still there.
I pulled the intake to check the shaft on the turbo and there is no play at all and the fins look good ( no dusting or chips).
Is there anything else it could be?
Also I used my 4wd the other day (by manually locking the hubs) and the passenger side won't disengage. It goes to the auto setting but the hub is still locked.
Any thoughts on that one?
Thanks
Old Mar 30, 2009 | 09:57 AM
muddiejeep's Avatar
muddiejeep
I got the hub fixed. A dead blow hammer took care of that problem.
Old Mar 30, 2009 | 09:59 AM
rbaker6336's Avatar
rbaker6336
you may need to take the hubs of and clean them
ajeffrey
Mar 21, 2019 04:51 PM
BigGreen7.3swap
Sep 28, 2014 10:13 PM
trike1946
13
Mar 14, 2008 08:28 PM
bumbklaatt
Jun 28, 2006 12:10 AM
BIG-BAD-794X4
General Automotive Discussion
Jan 19, 2006 12:32 PM
