Siren sound coming from engine compartment
I was driving my 6.0 excursion the other day and the pipe wich cools the turbo down blew off and the engine over heated. It sounded as if a tire blew. We re-attached the pipe,filled the radiator and started it. When we began to drive there was a siren sound coming from the engine. The sound winds down when I let off the pedal and can not be heard at idle. Any suggestions as to what the sound could be? I was thinking a leak in the turbo hoses or a bad turbo bearing.
The two most common siren sounds are from the Degas/overflow bottle cap or a leaking/split/cracked turbo hose. If you don't find a leak in any of the rubber turbo hoses then check the flex joints of the y-pipe that feed exhaust into the turbo from the exhaust manifolds. They are very prone to cracking and it's sometimes very hard to see. Look for exhaust leaks to point you to the offending area.
Did you ever find the issue?
Thanks!
eatont9999
28
05-14-2011 12:18 PM
RNH Performance
36
07-26-2009 05:45 PM
