Sponsored by: Auxito
dropping my 2002, any recommendations?
Old Mar 30, 2009 | 12:16 AM
triton_2002's Avatar
triton_2002
2002 F150, 5.4, supercab, 2WD.
I'm looking into drop kits for my truck and looking for some first hand experience with good/bad kits you may have used. I want a moderate drop, 2-3" front/ 4-5" rear. I already have 20" rims on it, but the suspension is all stock. I've narrowed it down to a drop kit from Truck Accessories | Pickup Truck Accessories & Truck Performance Parts | Stylin' Trucks. Its a 3"/4" drop kit with components from Belltech (lowering springs) and DJM (drop shackels/hangers/alignment shims). Shocks are separate, and I'm thinking to going with Belltech shocks. The drop kit is $310 and shocks are about $40/each. Any thoughts? I'm hoping to keep as close a possible to stock ride, possibly a little stiffer but not too much. Of course, I don't what any alignment problems either, I'll change ball joints, tie rods, ect, as needed.
Old Mar 30, 2009 | 06:18 PM
Smaug's Avatar
Smaug
I bought my drop components separate but I've got 3 in Belltech springs up frt and the DJM kit in the back. They are both good, solid parts. They've been on my truck for 4-5 years and I haven't had any problems with them. Go ahead and get a camber kit to put in while you're working on the frt. If the shocks you're looking at are the Belltech Nitro, please be aware that they only last about 25-30k miles. That's what I bought and they need replaced.
Changing the coil springs and shackles are EASY. The problem is going to be the hangers. I used an air chisel to cut the head off and couldn't get the rivets out. I beat on them, heated them up, beat on them with a bigger hammer, took it to the closest shop and they got them out with a sledgehammer. I got aggravated and didn't even think about drilling them.
About a week after I dropped it, I noticed the back drivers side was sitting lower than the right side. I got under it and the overload spring was gone. I pulled the one out of the right side and it makes for a much softer ride. Gives it about another 3/4 in drop too. Problem with that is the back end is going to sink. I recently put the factory shackles back on because the back had sank too low.
Old Apr 1, 2009 | 05:42 PM
triton_2002
the drop hangers replace the front or rear stock hangers? Do you have to get the gas tank out of the way? I'll probably take the parts to a shop to get it installed, I already got a project in my garage and my jack stands/jacks and room to work are occupied for a while. Whats in the camber kit? Shims for proper alignment? Do you need the camber kit for 2" lowing springs? I may get the drop spindles/springs if thats the case.
Hamfisted
Jan 20, 2017 12:09 PM
2.5itim
Oct 12, 2016 07:29 PM
ojh
Aug 27, 2016 12:24 PM
SatinBlack03
Jul 11, 2015 07:42 PM
Brian Fulcher
May 1, 2015 09:27 PM
