overdrive light is out
Old Mar 29, 2009 | 09:15 PM
Joeymt3's Avatar
Joeymt3
I've got a '99 explorer with a automatic tranny. the tranny is fine and the overdrive button works, it will take it out of over drive. the problem is that the light doesn't come on when overdrive is off. does anyone know if I can fix this?
Old Mar 29, 2009 | 11:29 PM
Joeymt3's Avatar
Joeymt3
the only indicator light to tell you that the over drive is off is in the gear shifter right?
how do you take the end off?
is there a bulb or LED that is replaceable?
Old Mar 30, 2009 | 02:02 PM
marragtop's Avatar
marragtop
Isn't the OD light off in the dash? If so, it's probably just a burnt out bulb.
Old Mar 30, 2009 | 04:12 PM
Joeymt3's Avatar
Joeymt3
is the bulb in the dash or is it in the shifter handle next to the button?
I had a 99 f-150 that had the light in the handle
Old Mar 31, 2009 | 04:40 AM
marragtop's Avatar
marragtop
My 95 has a bulb in the dash that says OD off when you push the button on the stalk in.
Old Apr 25, 2010 | 03:54 PM
Joeymt3's Avatar
Joeymt3
I found the light bulb in the dash to be burned out. it was not in the handle like my truck. thanks
Dbl A
Apr 8, 2017 02:28 PM
MT-F250
41
Feb 27, 2013 02:34 PM
ggirten
34
Feb 8, 2006 07:30 AM
FAGRO
Jan 19, 2005 08:00 PM
Henceforward
Apr 2, 2003 10:14 PM
