400 conundrum....
Old Mar 29, 2009 | 09:15 PM
hairyboxnoogle's Avatar
hairyboxnoogle
400 conundrum....
Okay... i have a 400 in my truck. Runs really good, edel intake. 600cfm carb.
Problem... it knocks. Dunno if its a rod or a main, but my bet is its a rod.
So, i dont want to put money into this thing, i will be replacing it. But until then i will be doing alot of driving, and quite a bit of towing. I need to wake this thing up a little. I heard that 400's have retarted factory valve timing. So for $40 bucks i can get an adjustable timing chain and gear set. Is it worth $40 bucks? What else can i do to it? I bumped ign. timing up a couple degrees, and that seemed to help. Was thinking about having the heads/intake milled say 30 or 40 thou.. but that gets into costing money again, and i dont think the bad bearing would like any more compression. Just looking for some ideas and help, thanks guys.
Old Mar 30, 2009 | 08:08 AM
mark a.'s Avatar
mark a.
I wouldn't put any money like that into a motor thats knocking. Time to replace, rebuild it. It's not going to last long with a rod knocking.
Old Mar 30, 2009 | 10:11 AM
MBDiagMan's Avatar
MBDiagMan
Been there, done that with the timing chain and it didn't work out good at all. My experience was on a 78 engine. I think the ones that respond to this are the early ones like the 73.
If it were my engine, I would feel the same as Mark regarding modifying a knocking engine.
Again if it were me, I would pull the pan and do a little exploratory surgery. Determine the problem, then formulate a plan from there. It very well might be that turning the crankshaft and replacing the bearings would get it all back in shape.
I would not just junk the engine without first doing a proper diagnosis.
Old Mar 30, 2009 | 06:10 PM
kettle-one's Avatar
kettle-one
^^ What they said. I would do anything considered "performance" to the motor until it is healthy. Depending on what you plan to do with the truck, you might be able to find a replacement for cheap and keep this one as a rebuilder. Is your truck a 4x4? Stick or Auto?
Old Mar 30, 2009 | 06:45 PM
Mud Rat's Avatar
Mud Rat
It's the famed Ford "Death Knock".
It could run forever as it is. Run it or rebuild it. Don't just tinker with it.
Old Mar 31, 2009 | 03:12 PM
hairyboxnoogle
Yea, my grandpa had one that knocked for 20 years... then finally just died from being wore out. This summer/fall im putting a 7.3 in it... thats kinda why i need to do towing and running. Its a 4sp 4x4. Lol.. and the trans is shot to boot. Thanks guys, thats what i was thinking, but if for $30 bucks i could gets a little more power.. i would.
