I am looking to get three gauges with there components,
fuel level
fuel pressure
"grease" temperature (water temp gauge range is good)
I would like the most stock looking gauges, the Auto meter GS look like the best match but they do not have a fuel level gauge. What would you recommend?
I have Dipricol Optix gauges in both PSD's. Here's the X:
The VDO fuel level gauge (under dash) matches well. You can put as many single-wire temp senders on a gauge as you want. I used a DPST switch in X, because wifey doesn't need too many choices - but a 6 pos rotary switch would be just as easy. Its good to know coolant temp too if ya plan to burn grease...
Heres mine at night, same dipricol optix. I have a whole bunch of other things, but my gauges are next to the dash, and then down were the ESOF would be. The air temp gauge, is not a dipricol.
Isspro EV2 will have an exact match to the factory lighting, factory font, and factory back ground. They were built to be an exact match to the Ford dashes.
They have everything you need other then the Grease temp, you could use a oil temp or water temp for that.
They also offer a Fuel Level gauge that works in conjunction with there fuel level sender. There sender is the best on the market, its been attempted to copy many times without sucess!
Talk to Clay about any Isspro gauges you might want or you can PM me for any info on them.
SkySkiJason that set up looks awesome, really clean!
I think I like isspro EV2 a lot, this might sound stupid but I cant figure out how to add the ones I want to my cart on there site to see the price??
you dont, you call Clay, and say "hey, what can you do these for" and he calls you back, you smile, you put your order in.. then you wait..at least that was my story... Worked out for me..
ANYBODY that doesn't call Clay for a price on anything before ordering will probably not be a happy camper!
Hey Clay....UPS just left and I'm holding my painted to match A-Pillar with Led. Now I just need to get together with Joe for a fun install time for the Pyro and boost Gages!!! Oh and by the way their Isspro's....top notch!
Thanks so much for the good price, top notch service and attention to detail.
Hahaha is that supposed to be me?? I have a much deeper voice!
