1966 Fuel Issues
Old Mar 29, 2009 | 07:42 PM
Brainard 66's Avatar
Brainard 66
1966 Fuel Issues
I just bought a 1966 F100. It turns over but wont start. Every once in a while it starts and runs for a few seconds and cuts off. It seems to be getting fuel to the in line fuel filter. Any suggestions on things to look for or try? Thanks for your help.
Brian
Old Mar 30, 2009 | 04:24 AM
camperspecial65's Avatar
camperspecial65
If it has the original type mechanical fuel pump, I would check the filter...it screws onto the pump itself...filters are still readily available...ND knows its Motorcraft number Im fairly certain...
If the trucks been sitting a while I would start there...drain the tank of the old crud if you havent already done so
The other thing it could possibly be is a bad accelerator pump on the carburetor.
Another possibility is if the fuel line going from the fuel pump to the carb is old and was replaced once upon a time with a rubber one and is harder then a fresh hose...replace it as these hoses rot in large part from the inside out...ESPECIALLY if the line that was used wasnt fuel line type hose...it will be stamped all over the outside of the hose...
You can also look for leaks at the other locations of the rubber hose line connections...theres 2 originally from the factory...right below the floorboard where the fuel line from the tank meets the line that runs along the framerail to the front where that line ends is another rubber hose that goes directly to the fuel pump.
Hope This helps, cs65
Old Mar 30, 2009 | 04:34 AM
jowilker's Avatar
jowilker
Old trucks only needed fuel and fire to run, properly metered of course.
One thing you might try is get a clear empty water bottle, remove the fuel line at the carb, (you might need a rubber hose on the end) and have a bud turn the engine over and watch the fuel dump into the bottle. You can pull the coil wire to make sure it wont fire or let it run for a few seconds if it does.
When you say it runs some it is getting fire, so I agree it more likely a fuel issue, that you will have to resolve. gluck
John
Old Mar 30, 2009 | 04:45 AM
camperspecial65
Dont forget oxygen...aka air...remember fuel/AIR mixture...
- cs65
Old Mar 30, 2009 | 04:54 AM
jowilker's Avatar
jowilker
Originally Posted by camperspecial65
Dont forget oxygen...aka air...remember fuel/AIR mixture... - cs65
You need to go to bed, it aint quite 6 AM on the right side of the world. You and da dummy running around in the middle of the night on the left coast.
John
Old Mar 30, 2009 | 11:35 AM
Brainard 66
THanks to all for the ideas. I will try them tonight and see what I find out.
Old Mar 31, 2009 | 04:37 AM
don merke's Avatar
don merke
66 fuel delivery prob ?
they could also come with a"carter"- brand> fuel pump ,>4/6 psi. is the working pressure /" 30 sec.cranking= 1-pint " if low or no fuel present pump is defective! {what size motor and carb type and conditionwould help diagnose the prob.> gas/spark/tuneup>>flame on
Brainard 66
Apr 23, 2009 12:37 AM
Brainard 66
20
Apr 9, 2009 08:33 PM
Brians1966
Paint & Bodywork
May 28, 2004 05:28 PM
Brians1966
May 28, 2004 04:40 PM
Brians1966
15
Dec 31, 2003 07:54 PM
