Sponsored by: Auxito
someone help me!
Old Mar 29, 2009 | 06:53 PM
rhyno's Avatar
rhyno
someone help me!
ok so i just bought a ford truck its an f-150 02 4x4 supercrew and i would like to put a lift on it. now ive looked around trying to figure out whats what and ive noticed body lifts are cheapest(the route i will probably go). now i have also seen these aftermarket leaf springs that can lift your truck as well. i would like to have my truck just a little bit higher than the body kit offers. so my question to you is can i combine the to to get a little higher than just doing one?!
Old Mar 29, 2009 | 08:53 PM
steve(ill)'s Avatar
steve(ill)
the problem is the front axle. you have torsion bars up front. you can crank them up and get about 1 inch lift. If you want more, you have to buy new torsion keys that have the key cut for additional lift. Too much lift on these front ends MIGHT put your half shaft or CV joint in a bind or excessive angle leading to more wear.
