Everything You Wanted To Know About The IWE System...And Then Some
My experience
Since I benefitted immensely from this thread I wanted to share my solution. I was getting the 4WD wrench alarm. I had previously swapped out the transfer case actuator so I knew it was good, and I tested it by driving down the alley in 4WD low. I have a 2010 F150 with about 140K miles, which has the vacuum solenoid on the driver's side on top of the brake controller. I purchased a hand vacuum pump and used the information in the original post to determine that the vacuum system was all good. (I did replace the vacuum solenoid because it was only $30 and 5 minutes to swap out.) I lifted the front wheels, connected the hand vacuum pump to the line coming from the solenoid and pumped vacuum down to 20 inches, where it stayed. I then turned each wheel and watched to see if the axle shaft turned with the wheel. Passenger side axle did not turn, driver side axle did. Released the vacuum and both axles turned. So I knew that the driver side actuator was stuck in the engaged position. I watched a few YouTube videos on how to swap out the actuator, purchased the new actuator from the local Ford dealer because they had it in stock (even though it was 50% more than online), and did the swap. You will need a few jack stands, a jack for holding the suspension up while you work with it and a bearing puller to help break the ball joints apart. In addition to basic metric sockets, you will need 18mm and 21mm deep sockets and a torque wrench capable of 185 ft lbs to put the brake caliper frame back on (I rented one). I used a Hayne's manual for the torque specs, but otherwise it is worthless for this task. Some of the videos online mention the correct torque specs as well. One important note is to not grease the axle any more than what comes with the new actuator, despite what you may see on some YouTube videos (got this tip from the Ford mechanic when I purchased the part).
When I removed the old actuator, I found that the gear ring had separated from the actuator bellows and so just kind of floated around inside. I suspect that it could have floated to the disengaged position if it wanted.
2102 F150 5.0 XLT 4x4
262,000KM (163,000miles)
I have 2 vacuum related issues. Perhaps unrelated… but perhaps the same cause?
I will do some poking around and try to see if there are any leaks in the lines or if any check valves are bad before I replace the defrost actuator and IWE. I was wondering if may be the solenoid?
If there is only one vacuum line from the intake and the solenoid distributes vacuum to both the airflow to the cab and the IWE… maybe that is the issue right there?
Any thoughts on these issues? Guidance?
Thx!
- When I switch into 4WD if seems that the system is engaged, but when I start up a hill and the truck is under load it will buck and bang like it is skipping gears somewhere in the front drivetrain. Also, the right front wheel fails to engage 4x4. No power to the right front when stuck in the muck. Left front and rear get power but not the front right (regardless of diff lock)
- When pressing defrost button, the infamous defrost actuator grind noise occurs. The sound goes away when the vent position is changed to feet or eyeballs. The radiator fan also kicks in while on defrost and continues for a minute after turning the defrost off.
Thx!
The solenoid for the IWE system does not have anything to do with the climate control system. Get yourself a vacuum gage, or better yet, a vacuum pump with gage. Otherwise you are just guessing. But since we are guessing, I think you have two separate problems.
TC
TC
tell me what i dont know
I have a 2006 F150 XLT 5.4L 4x4 automatic 173,xxx supercab. I got it at around 168,xxx for $2,800 from orig. $5k asking price. I've been running through it to give my son as a 16th bday gift. i collect fords & lincolns old & new. I LOVE FORD!!! Guy told me when i got it that it had a rough idle he was very forward & easy going. he said he aint the mechanic type as im not either but im learning alot. he said hed been told it was catalytic or injector. i had it inspected & they passed it with flying colors saying i ot a steal on it. i since then have done the following:
new motocraft platinum plugs & edelbrock maxfire coils
motocraft oil & oil filter
motocraft fuel filter
radiator flush
new fuse box & inertia switch
new doorman iwe actuators
new doorman 4x4 vacuum line assembly
new 4x4 vacuum solenoid (doorman)
new pcv tube & connectors
drained & flushed transfer case & filled with new motocraft mercon lv
cleaned maf sensor
cleaned intake
new intake gaskets
new thermostat & coolant crossover & gaskets
new throttle body
new vmv tube & connectors
new radio suppression capacitors
new altenator
new starter
new battery
new cables & terminals
new leds atw around except dash with relays
new ipr or fuel rail pressure/temp sensor
new imrc or intake manifold runner control module
new bosch o2 sensors all 4
....ive been thorough on the processes & specs yet ive still got a very loud hissing from driver side engine area & rough idle with engine light coming on. it dies even occassionally. a/c works great nothing leaks ever & nothing is reading on gauges as far as overheating, etc. aside from passenger air bag se sor light & the engine light its perfect. i reset it daily with my obd2 scanner. i cant find the sourse of the hissing which i presume to be a vacuum leak. also, my front end is still making the grinding clacking sound when driving & rear end makes moaning groaning sound sometimes 4x4 w0rks fine though kicks right in & ive repaced jt all as i listed above what csn i do???
radiator flush
cleaned maf sensor
cleaned intake
new intake gaskets
new throttle body
new altenator
new starter
new battery
....ive been thorough on the processes & specs yet ive still got a very loud hissing from driver side engine area & rough idle with engine light coming on. it dies even occassionally. a/c works great nothing leaks ... be a vacuum leak... also, my front end is still making the grinding clacking sound when driving
I've replaced what you have and have had it on my list of troubleshooting,...
For now, driving around with the front hubs engaged... uggh. let me know what you find. I have my suspicions on mine but do not have an obvious vacuum leak (hissing) like you do... use a vacuum line to your ear to find the source of the vacuum leak if you follow me...
Help me please
https://share.icloud.com/photos/08fb...y7E3BMkZyE1Cxg
https://share.icloud.com/photos/0de4...sYlrcr6OzsbPeA
https://share.icloud.com/photos/0b8H...fRw6AUuHZBXyxg
above are links to my iCloud Photos of a few videos I took today trying to understand why this is happening. Iwe and CV are new parts. Iwe is doorman and cv is duralast. Please tell me wtf is the problem here because I have everything aligned proper but when I torque down the bearing bolts it disengages with no vacuumed applied then Engages when I do apply vacuum. This is a 2004 f150 xlt crew crewcab with the 5.4l in it and the setup is vac=2WH no vac=4h & 4L.
understanings going in I am manually placing vacuum to Iwe and attempting complet proper install of new parts to fix a system that had stopped working as a result of water from switch geting in pass Iwe causing drivers side to skip in and out of gear so he didn’t ever put it into 4x4 for two year forgot to mention this is ESOF on the dash but you maybe already understood that
Nice
Recently bought a 2006 f150 4x4 I have changed the motor on transfer case changed the actuators on both front hubs when I went the change the vacuum selenoid it looks like it was bypassed selenoid not there just a bunch of wires a fuse and some type of breaker box Ok I want to go back to original set up but not sure on wires that go to the new vacuum selenoid Any help or pictures would be great
FordandSkeeter
Jan 28, 2005 09:03 AM
