Spark Plug change
Old Mar 29, 2009 | 03:58 PM
FordTruckGirl77's Avatar
FordTruckGirl77
Spark Plug change
My husband and I just changed our spark plugs and I was just wondering if you think by the condition of the plugs if we should have any concerns?
I was surprised at how easy it was to change them. The left rear one was a ***** but hubby only ended up with one scratched knuckle! Couldnt have done it so easy without the wonderful how to posts on FTE So a big thank you!!!
Old Mar 29, 2009 | 05:06 PM
Monsta's Avatar
Monsta
Sit. Stay.
Right ones are pretty white. Looks like a slight lean condition.
Old Mar 29, 2009 | 05:21 PM
ReAX's Avatar
ReAX
That's what I was thinking. I can't imagine four injectors failing the same way at the same time or there being a pressure problem in the rails. I think I would do the o2 sensors, just to have them reading the same. The ones on the left look pretty decent for mileage.
Old Mar 29, 2009 | 05:26 PM
FordTruckGirl77
Thanks for getting back, so you think we should replace both O2's? We did do the injector service because of the pinging and bad MPG's.
Old Mar 29, 2009 | 05:35 PM
ReAX's Avatar
ReAX
It would be my next step to seeing why one side is running so lean. Two new sensors would have you doing the job once and using sensors with a much closer manufacturing date. then I would do a bit of data logging to see what the o2 sensors had to say about the a/f ratio coming out.
Old Mar 30, 2009 | 11:20 AM
71-4R3SONS's Avatar
71-4R3SONS
They look pretty good to me...
Digital Photography surely (and don't call me Shirley) can give a false impression on things.
I'm going to guess there is a light source (possibly a window or open door) to the left side of the plugs???
Old Mar 30, 2009 | 11:48 AM
FordTruckGirl77
The picture was taken outside and yes more light on the left side but the right side did have the corrosion/white stuff on them.
I noticed today when I drove through the hills that i am still pinging and my son and I noticed a slight gas smell. Grrr when I got home i sniffed the front end and could still smell a small amount. Getting ready to go out and see where it might be coming from.
Old Mar 30, 2009 | 02:13 PM
Monsta's Avatar
Monsta
Sit. Stay.
Not to be a butthead, but are you SURE it's pinging you hear? Some folks have thought that a loose exhaust shield sounded like pinging since it would only do it at a particular RPM range & throttle setting. Same goes for the tranny inspection cover. Broken exhaust studs can fool a person as well.
Old Mar 30, 2009 | 02:45 PM
FordTruckGirl77
It is a ping for sure, It used to have a loose heat shield but that has been fixed and it sounded different to me. I think I may have it checked out by some friends who work at Ford, hook it up to the computer and what not.
Old Mar 30, 2009 | 04:05 PM
71-4R3SONS's Avatar
71-4R3SONS
Originally Posted by Monsta
Not to be a butthead...
You butthead.
Haven't heard that in a few months... LMAO.
gogreenwave
Feb 27, 2014 09:53 AM
B Dobz
Mar 27, 2012 03:44 AM
BlackNGoldRules
1983 - 2012 Ranger & B-Series
18
Sep 2, 2009 12:03 PM
mainman
2004 - 2008 F150
Jul 25, 2009 12:15 PM
bwinterr
Apr 1, 2005 04:56 AM
