Front End Driving Me Crazy
Old Mar 29, 2009 | 02:44 PM
wideopen23's Avatar
wideopen23
I posted about a week ago about some front end problems, anyways i have 2002 4x4 the front end is making a weird sound it only goes in spurts of 1 or 2 seconds then goes away then comes back, I dont even know how to describe it. I replaced the hub assembly thinking that was it, while I was in there I replaced rotors and shoes they needed it. Drove the truck with no front brakes around the neighborhood to see if it was the brakes and it made the same sound. So it doesnt seem to be a brake issue. The front end is tight cant find any movement. This is frustrating the crap out of me. I dont want to dump any more money without some help. Any thing I am missing? What does it sound like when the sway bar bushings go? ANy help is appreciated.
Thanks
Justin
Old Mar 29, 2009 | 02:58 PM
lowbed dud's Avatar
lowbed dud
spray some wd40 on sway bar bushing then drive and see if that helps,might be
shocks also, if stops with wd40 then new bushing, hope this helps
al
Old Mar 29, 2009 | 02:59 PM
triskit16's Avatar
triskit16
Sway bar bushings just make a thud type noise going over bumps...
Did you install the thrust washers correctly when you installed the hub?
Old Mar 29, 2009 | 03:16 PM
wideopen23's Avatar
wideopen23
I put everything back together the right way... I guess the sound is kinda like a brake shoe cackling off the rotor, but like I said I drove it without the caliber on and it made the same noise....
Old Mar 29, 2009 | 04:39 PM
randomhero1172's Avatar
randomhero1172
My front end was a mess, i couldnt do ball joints (4x4 hubs bearings! disaster) so i brought it to a shop and they quoted me $1500 for a rebuild (ball joints, control arms, all bushings, shocks, etc) and a drive shaft rebuild (all u joints and something with the TC ... also re balance) and an alignment. Truck drives frickin great now, like new! still expensive but it needed to be done.
Sharpshooter77
Dec 23, 2006 05:02 PM
justintino233
Sep 7, 2006 01:58 PM
Justin G
Escape & Escape Hybrid
Aug 31, 2006 10:42 PM
Merkulator
Jun 14, 2004 05:31 PM
Justin89
Dec 1, 2001 04:45 AM
