Waterpump pulley help
Old Mar 29, 2009 | 08:09 AM
FordF350Baby's Avatar
FordF350Baby
If someone can lend a hand here that be great. Alright, the other day when I was replacing the radiator, I also removed the fan and shroud to have more room.I then had completely forgot like an idiot to put the fan back on, and when i started the truck for leaks, the belts all fell off ect..So I was able to get the belts back on, but the waterpump pulley (has two idlers on it) does not seat well. Howcome this pully doesnt have some sort of nut to keep it on? It just sort of sits there, without and torque to keep it from flying off..Did i lose a nut or something? I know theres 4 nuts to keep the fan on, but that only attaches to a lose pulley, so I would imagine if i tried hooking it all back up, that the fan would go flying through the hood.
on a 1995 with 460
Old Mar 29, 2009 | 09:57 AM
smoke n tires's Avatar
smoke n tires
the 4 bolts go through the fan and pulley to thread into the water pump flange if its like the older 460, this holds everything together.
Old Mar 29, 2009 | 10:29 AM
ArdWrknTrk's Avatar
ArdWrknTrk
pedant
The fan bolts to the fan clutch, and the water pump flange bolts to the fan clutch flange, with the pulley sandwiched in between.
But I don't know about the Serpentine setup..
Old Mar 29, 2009 | 11:18 AM
FordF350Baby
Originally Posted by ArdWrknTrk
The fan bolts to the fan clutch, and the water pump flange bolts to the fan clutch with the pulley sandwiched in between.
okay thats what my problem is, the waterpump pulley isn't fastened.
vector
Sep 1, 2013 07:42 PM
kram32
Dec 30, 2012 01:04 PM
Big Skier
Jun 3, 2012 12:39 AM
gneill794
Oct 25, 2008 08:45 PM
