Head gasket
Old Sep 11, 2015 | 01:55 PM
#01truckfan's Avatar
#01truckfan
Head gasket
I have a 1990 302 f150 with 160000 miles and I need to replace the head gaskets and lifters and rod end and main bearings now is the head bolts torque to yield or reusable and what is the head bolt torque sequence and any thing else I should do while i am there
Old Sep 11, 2015 | 02:04 PM
Diesel_Brad's Avatar
Diesel_Brad
If you are going to go thru all that get yourself a manual.
beter yet, just buy a reman engine with a warranty
Old Sep 11, 2015 | 05:03 PM
timbersteel's Avatar
timbersteel
Those head bolts are the old style. But, if its been touched, check to see if the hex head has a flange. If there is a flange, then they are TTY.
If you use Fel-pro, there is instructions on the sequence. Very easy.
gameover1974
19
Dec 18, 2015 02:15 PM
fasthauler
3.8 & 4.2L V6
Jan 24, 2009 11:28 PM
IanR
Mar 18, 2008 03:46 PM
lcoldwell
1978 - 1996 Big Bronco
Mar 3, 2001 05:33 PM
sjleslie
Sep 28, 1999 09:01 AM
