alignment
Old Mar 28, 2009 | 02:43 PM
crazer42's Avatar
crazer42
alignment
is there a way to tell if your front wheels are still properly aligned?
Old Mar 28, 2009 | 02:55 PM
guthrie&co's Avatar
guthrie&co
You should be able to tell by looking at the wear patterns on your tires. If the tires are worn in an abnormal pattern that is an good indicator. If you have to hold the wheel to to one side to go down the highway straight then yes you would need an alignment
Old Mar 28, 2009 | 05:24 PM
crazer42's Avatar
crazer42
well i answer yes to both my pattern is worn bad and i need to hold to the left to stay straight. what problems could this cause?
Old Mar 28, 2009 | 05:36 PM
RRranch's Avatar
RRranch
It can cause your tires to wear out as you already discovered and also cause control problems while driving.
Be very careful and picky about who you choose to align it. The Ford dealer is the only garage I'd recommend but only if their tech is good with these trucks. A lot aren't any more.
Once you get it done, if your steering wheel is the least bit crooked when you let go of it driving in a straight line then take it back immediately and tell them to redo it.
Old Mar 28, 2009 | 07:06 PM
crazer42's Avatar
crazer42
so could that explain why, at certain speeds when making a slight turn my wheel shakes back and forth
Old Mar 28, 2009 | 07:45 PM
swaybar's Avatar
swaybar
i put in two new tie rods last week, then brought it to the shop and had it aligned and i'll tell you, it handles the *****. i never thought it was bad before but after the alignment and new tie rods it like a new truck. drives really nice!
get it done when you can, you'll be glad you did. makes driving much more enjoyable.
Old Mar 29, 2009 | 03:39 PM
aldridgec's Avatar
aldridgec
You need to make sure you don't have any worn suspension parts. Wheel alignment in itself doesn't cause vibration, unless it is horribly bad.
There are 3 main things that contribute to a wheel alignment. Toe, camber and caster.
Toe contributes to wheel centering, inside and outside edge wear. It doesn't necessarily contribute to pulling, or drifting to one side.
Both camber and caster can affect pulling and drifting.
Camber can show as tire tread wear across a significant portion of the tire tread.
Caster affects steering wheel return to center.
Only toe and centering are readily adjustable on the superduty.
