300 six 64 trans
Old Mar 26, 2009 | 08:51 PM
64f2504x4's Avatar
64f2504x4
300 six 64 trans
anybody know if a 300 six or 390v-8 will directly bolt to my 64f2504x4 trans---have 292 now but noticed rebuild kits and long blocks quite high......
Old Mar 26, 2009 | 11:11 PM
flipklos's Avatar
flipklos
I belive the 64 4x4 used a divorced transfercase?
Install a 300 or 390 with its original transmission. I belive the T98 will mount to the 300 and FE bellhousing. However,
You need to install or make a engine and transmission crossmember.
390s and 300s are side suported engines utalizing a transmission crossmember for suport. The 292 Y block is supported front and rear with the trany hanging off the engine.
The 300 is my favorite engine of all time and I love the 390 as a go fast powerplant. I can order a basic rebuild from my parts store for about $900 in parts. That is for a complete overhaul, W engine mounts. $300 in machine work and you've got a new engine.
Buying the parts to install the 300 corectly is about $350 assuming youve got a good engine. I wanted to do this myself so I looked into it. That is an aftermarcet crossmember. Homemade trany support, custom drive shaft, and engine mounts. I belive a 390 would be compareable in conversion cost.
The 292 is a great motor. I ve got a 64 F100 w/ one.
If you want more info on converting or help with parts Im sure we will be here.
Old Mar 27, 2009 | 03:41 PM
64f2504x4's Avatar
64f2504x4
thanks for info my 292 runs strong light smoking--just todays gas and yesterdays gas maybe nolead would hurt vavles-don't know myself, but driver side exhaust manifold 2 cracks top of manifold middle crack completly pretty soon headers be great got info on headers???price etc.......
Old Mar 27, 2009 | 08:56 PM
billy12360's Avatar
billy12360
redsheaders... about 200 dollars but fire fox is saying it cant connect to their web site for some reason... try it out anyways 1954-64 Ford Y-Block headers and engine parts at Red's Headers & Early Ford Speed Equipment
Old Mar 27, 2009 | 09:26 PM
flipklos's Avatar
flipklos
Dont own them but I would sugest ramhorns. They are cast iron exhaust manifolds that flow a bit better then stock. No header clearence issues to deal with and no warped header flanges.
Add lead substitute to your gas at every fill. I use CD2 as I find it a great bang for the buck. $8 worth is good for about 250 gallons.
Try adjusting your valves too. Factory spec for 64 is .019.
Old Mar 27, 2009 | 10:55 PM
billy12360's Avatar
billy12360
Headers - Full Length for 2wd (not lowered) '54-'64 Truck [550-558] - $225.00 : Red's Headers, Speed Equipment For Old Fords those are the ones i own... i finally relized... it is .net not .com lol no clearence issue, other then the fact that the reducers i think they are called are a bit to long... and need to be cut a little bit... but im still fine with the way they are...
Old Mar 28, 2009 | 08:38 AM
64f2504x4's Avatar
64f2504x4
thanks for info,was able to find site--price 130 bucks cheaper than '07 issue of lmc
Old Mar 28, 2009 | 08:39 AM
64f2504x4's Avatar
64f2504x4
thanks for info--start using gas additive...
Old Mar 28, 2009 | 09:09 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by flipklos
. 390s and 300s are side suported engines utalizing a transmission crossmember for support.
The 292 is a great motor. I have a 1964 F100 w/one.
Sorry, that engine mounting info is in-correct.
Better take another look at your 292 engine mounts.
The front of the engine is supported in the center by upper and lower donut shaped rubber insulators.
The rear of the engine is supported by two donut shaped rubber insulators per side.
These insulators attach above and below the crossmember you say these trucks don't have.
Old Mar 28, 2009 | 11:32 PM
billy12360's Avatar
billy12360
edit to my second post... i own the stubies not the long tubes... the stubies dont require lifting the engine like i hear everyone else has to do with other type of headers... but they might just be talking about the 352 and 360s and 390s... that they have to do that on...
Old Mar 29, 2009 | 12:24 AM
flipklos's Avatar
flipklos
I know alot of people will disagree but headers are a lot of hype. Very few are designed to benifit in the primary operating range of a truck. In my experience (3 pairs) They all leak. If you plan on seting up at a 5k rev and working there they work. I like cast iron. Headers never seem to seal, add a ton of heat to the engine compartment. Do what you like. My buddy wants them on his 390 68 galixie. WHy not hipo factory cast manifolds?
To each their own. Paint the gaskets with copper headgasket sealent or gold spray paint, Run big washers to spread the force. Good luck and good night.
NOTE: I was considering getting headers till I found the ram horn manifolds. Even a skeptic has his downfall.
F2504x4
17
Jan 11, 2004 10:36 PM
79F2504x4
Jan 15, 2002 08:51 PM
1970f2504x4
Oct 8, 2001 10:20 PM
1970f2504x4
Apr 20, 2000 06:15 AM
