Sponsored by: Auxito
PVC hose assembly
Old Jul 22, 2005 | 01:31 PM
northernowl's Avatar
northernowl
PCV hose assembly
I need to replace the PVC hose assembly as it is cracked. Should I replace the PCV (edit) Valve at the same time. If i do what brand should i use.
Old Jul 22, 2005 | 02:16 PM
MrBSS's Avatar
MrBSS
I assume you mean PCV, and if you replace it, use a Motorcraft. I have heard that there have been some problems with other brands (seems unlikely with such a simple device, but not worth taking a chance on).
However, they seldom need replacement (usually just cleaning). On the other hand, they're cheap enough that you almost might as well do it at the same time. Your choice!
Old Jul 22, 2005 | 02:17 PM
mel2000f150's Avatar
mel2000f150
Just replace the hose. The PCV should be OK, if the ball inside is still moving around.
You can spray a little WD40 in it, if it is stuck.
Old Jul 22, 2005 | 03:39 PM
lancekilgore's Avatar
lancekilgore
there is another test you can do on the pcv valve air should only flow one direcrion if you blow on one end (not sure which end) air should flow freely, then blow through the other end and no air should pass through if it does then the valve needs replaced. But I agree that either you can clean it or replace it they are not very expensive.
Lance
Old Jul 31, 2005 | 10:33 PM
racesidner's Avatar
racesidner
Question PCV Valve
I just got a 2001 ford super crew with the 5.4 and when it is running you can hear a buzzing sound under the hood, i opened the hood and got to feeling around and when i grab the pcv valve it is buzzing and vibrating like crazy, is this normal?
Old Jul 31, 2005 | 10:44 PM
Torque1st's Avatar
Torque1st
Posting Legend
Always replace the PCV valve. Just because they rattle or you can/can't blow air thru does not mean they are any good. They DO wear out and should be replaced annually.
Old Aug 1, 2005 | 08:28 AM
lancekilgore
Yes I do agree and beside they are only a couple of bucks so better to be save than sorry.
Lance
Old Aug 1, 2005 | 05:34 PM
blazerf250's Avatar
blazerf250
Exclamation Pcv and tube!
I bought a new tube at the dealer and it came with the pcv valve! All in one! But like $18! Thought you might like to know!
Old Aug 1, 2005 | 09:50 PM
lancekilgore
why did it come with a new hose you only replace them like never, unless they are clogged or leaking. HMMMMMMM. although if the PCV valve passed the test I prescribed I would not have changed it. sporry if I led you down the wrong road. all the pcv valves i have dealt with have only cost 2 to 3 dollars. but usally I do the blow test it it past I don't change. they last a long time.
Lance
Old Aug 1, 2005 | 11:39 PM
blazerf250's Avatar
blazerf250
PCV Tube!
I had to replace the tube and it came with the pvc valve! I could not get just the tube by itself from the dealer! Sorry for the misunderstanding. Maybe other dealers had them separate but not mine!
Old Aug 2, 2005 | 08:41 AM
lancekilgore
Got it, you are better off with the OEM part (TUBE) but you could have also gone down to the autoparts store and bought the two feet of hose for 2 or 3 $ and had the same thing. It would not have come with the special cover the ford part did.
Lance
Old Aug 4, 2005 | 08:12 AM
racesidner's Avatar
racesidner
Question PCV Valve and Hose
Does anyone have the ford part number for this item?
Old Aug 4, 2005 | 09:19 AM
MrBSS's Avatar
MrBSS
F7UZ-6A666-CA; PCV Valve- without hose (That's what they gave me for a 2001 4.6).
Old Dec 27, 2006 | 04:43 PM
lance242's Avatar
lance242
hey racesidner did the buzzing noise stop? i have the same prob in my '97 5.4. it also runs bad w/no trouble codes. did the PCV replacemnet fix it?
Old Dec 27, 2006 | 10:40 PM
projectSHO89's Avatar
projectSHO89
Replace the PCV valve with a Motorcraft (not aftermarket) replacement.\
Steve
