07 fx4 with positrac???
Old Mar 26, 2009 | 11:51 AM
07fordfx4's Avatar
07fordfx4
I have a 07 f150 fx4 5.4, and i have heard that the fx4's come with positrac, unlike the regular 4X4's. what do you guys know 'bout this????
Old Mar 26, 2009 | 12:27 PM
Ford Fx4's Avatar
Ford Fx4
If it is a Fx4 they come standard with a Limited slip, I have seen a few with a 3.55 but most have the 3.73 ratio. This is the same limited slip that you would would get if you got a non 4x4 or normal 4x4 also, no difference between them.
Now just new for 09, only on the Fx4 it has a electric locking rear differential. By pulling the switch on the dash you lock the rear axle completely. It will stay locked until to 65mph in 4 Hi and 25 in 4 low.
Old Mar 26, 2009 | 09:18 PM
screwy's Avatar
screwy
Great information above, I just wanted to add the stock LS is pathetic, so don’t expect great things from it.
Old Mar 27, 2009 | 09:25 AM
jsoko's Avatar
jsoko
on dry pavement my 3.73 LS smokes both tires
Old Mar 27, 2009 | 11:33 AM
Ford Fx4's Avatar
Ford Fx4
X2
I have yet to be disappointed by mine. About 3weeks ago about I was driving up a real steep driveway that was half ice on one side and the other dry pavement. I was going to put it in 4x4 before I started up but thought what the hell lets see if I can make it up. Started up and when one tire hit the ice and started to spin it locked up and took me right up the hill. Grated it kept locking and unlocking and some spinning but it got me up the hill! I guess I must have a good one
Old Mar 27, 2009 | 01:19 PM
silver05fx4's Avatar
silver05fx4
well my 05 had a good ls that would smoke my 35's till i got stuck and burn the clutchs up in it
Old Mar 27, 2009 | 05:10 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
people always rag on the stock LS...and when asked, most of them have huge tires and/or have beaten the crap out of it
the normal everyday person will have 0 issues with it.
my LS worked perfectly for 23,500 miles. Recently though, I've been experiencing some 1 tire fire. But that has been in the last 2,500 miles or so (only 25,800 on the truck).
Normally lays down dual black marks, but the single black lines are appearing with more frequency.
I don't blame the stock LS though. I'd like to see any factory unit or aftermarket unit take a hard launch in a truck with 400+ HP and weighs 6,000 lbs
just gives me an excuse to upgrade to a detroit locker when I do gears
Old Mar 28, 2009 | 08:28 AM
WhëëlMå1's Avatar
WhëëlMå1
If you all want something to complain about, you should see the POS LS in my 08 F350. The LS I had in my 06 F150 was light years better.
Old Mar 28, 2009 | 09:27 PM
screwy's Avatar
screwy
Hmmm, then mine must be broke cause I only have 3000 miles on it, stock tires, and it'll only spin one tire if ones on pavement and the other is on ice.
Old Mar 28, 2009 | 10:24 PM
jsoko's Avatar
jsoko
which tire spins?
Old Mar 29, 2009 | 02:49 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
when you have spinning, how fast does the speedo read?
the LS is a set of clutches. They don't work until there is a little wheel spin to create some friction...then they grab and force both sides to work.
and are you positive you have the LS rear end? 3,000 miles is extremely early for the LS to not be working already
I'd take it by the dealership and make them fix the LS if it is one. Might be something as simple as needing a little Friction modifier, or the clutches are shot
Old Mar 29, 2009 | 08:43 AM
jsoko's Avatar
jsoko
what Tylus said is right.
look at drivers side door jamb sticker
see axle number?
19 = 3.55 non LS
18 = 3.08 non LS
H9 = 3.55 LS
B6 = 3.73 LS
this may save trip to dealer
Old Mar 29, 2009 | 12:34 PM
screwy's Avatar
screwy
which tire spins?
The one on the ice.
Think I had it as fast as 25.
see axle number?
19 = 3.55 non LS
18 = 3.08 non LS
H9 = 3.55 LS
B6 = 3.73 LS
B6, I already knew that though, it was one of the things I checked before buying it.
The thing is it has the same winter driving characteristics as my 07 had, B6 also, though admittedly I never got it stuck where I could really tell what the LS was doing like this one. Well back to the dealer, I’m beginning to think I’ve got a lemon.
Old Mar 29, 2009 | 12:54 PM
jsoko's Avatar
jsoko
take 2 pair of Boxing Gloves, cause he's gonna make a BIG DEAL about the ICE
if you got ice, find some mud try again
dont see much Ice down here
oh by the way Welcome to the Site 07fordfx4
Old Mar 29, 2009 | 01:14 PM
screwy's Avatar
screwy
Oh? Why is that?
