Cheap E4OD alternatives???
Old Mar 25, 2009 | 07:59 PM
therifleman556's Avatar
therifleman556
Some of you have already assisted with explaining what is needed to swap our '93 7.3L 4X4's E4OD out for a C6. From the way things sound the level of difficulty would be very simmilar between swapping in a C6 or a manual trans. The question now is what is the cheapest option for replacing our worn tranny? NP435's are a dime a dozen but will their gear ratios pose a problem for the diesel and is it possible to even get a bellhousing for it? Someone suggested a T19, was this the 4spd option available in the 6.9L trucks? The NP might pose a problem with its divorced transfer case design. Did the T19s use the same transfer case as the C6 and E4OD? A rebuild for the E4OD is in the neighborhood of $2000 and thats probably more than what the truck is worth if the tranny was still good, however, I don't think I could bring myself to part this truck out with a good motor and solid running gear. Any help is appreciated...
custom1106
Nov 4, 2013 03:45 PM
boots6868
May 14, 2011 06:59 PM
therifleman556
May 10, 2011 10:47 PM
therifleman556
24
Apr 4, 2009 02:54 PM
