Sponsored by: Auxito
BB's in a coffee can.
Old Mar 25, 2009 | 02:37 PM
leforrest's Avatar
leforrest
98 4.6 4x4
Thought maybe it was Ujoints, but they appear to be reasonable tight. When starting off I have no issues...no noises...no vibrations. While driving and under power...nothing...
When coasting...I have a slight vibration and what sounds like 15 bb's tumbling around in a coffee can. It has that real thin metal sound. I wrote the Ujoints off, but I suppose if they were worn to an unusual shape now that the bearing are shot that maybe the noise could be resonating up throught the driveshaft, which is thin.
I pulled brakes today to see if there was anything in my drums and came up with nothing..
The sound is definitely rotationally effected.
Im completely stumped. I threw the truck in neutral and applied the ebrake. I got about 2 inches of rotational travel out of the shaft. I didn't get any up and down play at the joints to speak of. When rotating...it rotated within the tranny and rear diff. IT DID NOT rotate at the joints.
I also wanted to add. Speed is not an issue. I have a driveway with a wall on both sides and can hear the SLOW rattle even at 2mph when I pull down my driveway
Any ideas.
Old Mar 25, 2009 | 04:15 PM
Thomas Hutchins's Avatar
Thomas Hutchins
This may sound dumb, however based on an Old trick from years past, but do you have some type of hub cap on the wheels and if so have you checked them to be sure someone has not put gravel in them.
Old Mar 25, 2009 | 04:58 PM
jcee's Avatar
jcee
I had a similar noise in my 06' that sounded to me like a loose clamp on an exhaust pipe. I was all over that thing looking for a loose bracket, strap, clamp or other type of metal to metal rattle. On the second dealership trip they noticed a TSB for a relay that either actuates or disconnects the 4 wheel drive. I believe it's vacuum controlled. I don't know if it covers the 98's or what years for that matter
If we can get Tylus to weigh in he knows the name of the relay and it's function.
Tylus?
Old Mar 25, 2009 | 05:28 PM
leforrest's Avatar
leforrest
I appreciate the posts guys.
I did have the wheel caps off today to check the brakes. They are plastic and and I didn't notice anything inside of them when I took them off.
Jcee.
The sound I am getting only occurs when I am moving and coasting. I would think if it's electronic it would occur when that system is intiated. Not just when at a coast.
When I go slow or fast at a coast the sound is in sync with the speed I am traveling.
If you took a coffee can and turned it sideways and threw 15 BB's in it and spun it like a rock tumbler...that is the sound I am getting. I can't imagine any electronic device sounding like that. It's loud enough to echo off jersey barriers and walls when I drive by them.
Maybe Im a fool, but it seems mechanical.
Thanks.
Old Mar 25, 2009 | 06:40 PM
jcee's Avatar
jcee
BB's
I didn't mention anything being electronic. This was a VACUUM actuated relay that was the problem in mine. It also varied in noise level related to speed. The relay itself did not seal and would not hold the vacuum according to the tech at the dealership causing a rapid open/close condition hence the rattle.
Old Mar 25, 2009 | 07:44 PM
leforrest's Avatar
leforrest
Hmmm. When you said relay, I automatically assumed.
Did it sound like it was coming from the rear of the truck?
Did it only do it when you were coasting?
Thanks. This would be pretty funny if this was the case. LOL
Old Mar 25, 2009 | 08:01 PM
jcee's Avatar
jcee
Mine sounded more from the right front. You could hear it on the open road but when there were barriers or another vehicle passed me it sounded like it was comin' apart! I did not hear the rattle when coasting. Is yours more from the rear of the truck?
Old Mar 25, 2009 | 08:31 PM
leforrest's Avatar
leforrest
Yeah....seems like it's coming from the rear...but, directly underneath. It doesn't seem to favor one side or another.
Old Mar 26, 2009 | 04:20 PM
leforrest's Avatar
leforrest
Welp.
I replaced both front and rear Ujoints cause that's the only thing IMO left that it could be.
The front Joint on the rear driveshaft was perfect. The back one was shot.
I replaced both and have no issues at this time. No sounds....nothing.
Never in all the trucks I have owned have I ever had a driveshaft make this kind of sound. Like I said in my original post, best I can figure is the back joint in the got sloppy and resonated up throught the driveshaft.
Thats That. Thanks all.
Old Mar 26, 2009 | 04:55 PM
jcee's Avatar
jcee
It's hard to believe a noise like that could come from a U joint that didn't vibrate at some speed or coasting. Every U I ever replaced either vibrated under power and clunked on take off or just plain fell out (there's an experience! ).
Come to think about I did have a CV joint make a squeel/squeak when it rotated. The ball between the joints was the culprit there. Glad you found it.
I hate to spout an old cliche but....It's always the last place you look!
Old Mar 26, 2009 | 06:09 PM
leforrest's Avatar
leforrest
Yeah Jcee...I never figured it either. At least it wasn't expensive. LOL.
I can say this. The front joint was fine.
Back joint.....
Follow me here for a second. A Ujoints have 4 pins and caps.
2 pins were fine with grease. Both opposite of one another.
1 pin was dry, but still had the needle bearings in it.
The last pin across from that dry one was demolished.
Best I can figure is in a coast the one dry pin with no bearings was slapiing around inside the cap everytime it spun around.
Whether or not it's the case, I don't know....It's fixed though. Thats all I care about. Now...onto the manifolds....Grrrr....
Old Mar 27, 2009 | 09:58 PM
barnettdh's Avatar
barnettdh
Check the heat shield over the catalytic converter.
Old Mar 28, 2009 | 02:01 PM
leforrest's Avatar
leforrest
As said in the previous post.
It was the Ujoints.
Thanks
Old Mar 28, 2009 | 08:10 PM
barnettdh's Avatar
barnettdh
Sorry. Somehow I missed that.
jeepfix
Aug 22, 2015 09:18 AM
stevebigos
Nov 17, 2013 09:17 AM
TonyJestis
15
Nov 5, 2012 06:13 PM
Mr.Russell
2004 - 2008 F150
Aug 7, 2008 10:20 PM
gustaf
Nov 19, 2005 08:26 AM
