GM engine EFI harnesses, supplier
Old Mar 25, 2009 | 01:14 PM
sdetweil's Avatar
sdetweil
I have been looking at a custom GM engine for one of my future projects. Its EFI of course, so this leads to the dreaded harness cost problem..
I found a place thru an engine builder that almost seems reasonable, less than $300 for a harness..
Fuel Injection Connection
Sam
Old Mar 25, 2009 | 01:49 PM
ferguson777's Avatar
ferguson777
Check out the Detail Zone .
Got a "custom" harness for a Ford 5.0 and was real impressed with the completeness, engineering and service.
Old Mar 25, 2009 | 02:39 PM
RUSTY50F1's Avatar
RUSTY50F1
Sam; I am in the process of doing this same install. The cheapest harness I have found that has everything you need is over $700. How much is this harness your talking about and does it come with the ECM or do you have to buy all the extras. If it is under $300 and has everything needed to install and start the engine I want one NOW. Thanks RUSTY
Old Mar 25, 2009 | 02:53 PM
sdetweil's Avatar
sdetweil
looks like you still have to come up with the ECU regardless of where you go.
for example from the 'catalog'
Tuned Port EFI with 700R4 Trans
Part # 1121-0012-N, $245, This harness has all of the features that are needed to transplant the TPI engine out of a 90-92 Camaro or Corvette. The emissions equipment are not part of this harness. This harness will allow you to install a TPI engine out of a Camaro or Corvette with all of the sensor connections needed to operate as a 1990 to 92 Camaro MAP system. The computer and chip are not included. It will allow you to use the 700R4 transmission
94-95 TBI 4L60E Transmission
Part #2523-2042-N, $295, Made for 1994-1995 TBI engine and transmission combinations. Also used as a 4L60E conversion harness for transplanting the 4L60E transmission. It has all of the basic funtionality to run the 94-95 TBI engine with no emission equipment.
and for example, the TPI installation instructions
http://fuelinjectionconnection.com/gpage3.html
Sam
Old Mar 25, 2009 | 03:01 PM
sdetweil's Avatar
sdetweil
this is one of the engine configs
Old Mar 25, 2009 | 03:12 PM
RUSTY50F1's Avatar
RUSTY50F1
Looks like I'm out of luck; Mine is an 89 with MAF Wonder is they make one for it to didn't see where a person could contact them to ask.
Old Mar 25, 2009 | 03:14 PM
sdetweil's Avatar
sdetweil
FUELINJECTIONCONNECTION.COM 303-641-6400
Sam
most don't like MAF due to the large intake tube that clutters up the scenery.
(detail zone says this on their site)
Old Mar 25, 2009 | 03:23 PM
RUSTY50F1's Avatar
RUSTY50F1
I found a email address and sent them a email if they can make one I'll order it. I like the MAF because I have a Large cam in it and didn't have to change anything.
Old Mar 25, 2009 | 04:27 PM
Last Chance 56's Avatar
Last Chance 56
speedway motors has the oil burning harness
Old Mar 25, 2009 | 10:43 PM
dongc1's Avatar
dongc1
When I did the 86 TPI in my 50, I got the harness with the 4 ft extra length from Painless. Worked out perfect. I put the ECU and all of the relays behind the seat and ran the wires out the hole in the floor where the gas tank used to be, came up behind the engine. I seem to recall that it was about $400.
Old Mar 25, 2009 | 11:09 PM
sdetweil's Avatar
sdetweil
painless shows $515 (TBI) and $580 (TPI) now.
sam
Old Mar 26, 2009 | 12:39 AM
RUSTY50F1's Avatar
RUSTY50F1
Painless is kinda like Barrett Jackson they think everything they have is made of gold.
bigfootsurfin
WTB - Ford Trucks & other vehicles
Oct 28, 2014 01:16 AM
reed1951
Jan 25, 2013 07:17 AM
sdetweil
Dec 3, 2011 09:24 AM
Rusty_Old_F250
Nov 19, 2011 03:38 PM
sdetweil
Jul 6, 2010 10:59 PM
