Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 SVT Ford F150 Lightning, Roush, Saleen and other performance F150's
how much oil?
Old Mar 10, 2002 | 03:07 PM
kluxman45's Avatar
kluxman45
how much oil?
just changed my oil for the first time and filled the filter up then added the rest of the oil.i bought 5 qts. no reading.how much do they hold?
Old Mar 10, 2002 | 06:10 PM
Lightning Rod's Avatar
Lightning Rod
how much oil?
Six with a filter change.
Old Mar 11, 2002 | 04:52 PM
kluxman45's Avatar
kluxman45
how much oil?
;-) well i got it all changed.it took 7 qts with a filter to fill it
Old Apr 10, 2002 | 08:14 PM
SVT_snoopy's Avatar
SVT_snoopy
how much oil?
Seven??? Manual sez 6, SVT reps say about 5.5 . I changed mine recently, with filter, and at 5.7 it was just about perfect.
Methinks you may have overfilled.
Old May 11, 2002 | 11:59 AM
xjmd44's Avatar
xjmd44
how much oil?
Hello All!
To share my experience...filling the case w/5.5 qts is just right!
When filling to 6qts, I observed oil getting into the intake boot and other associated hardware.
J. Mark
2000 White Lightning # 149
2001 Red Lightning #2633
Magnaflow 12468.
No engine or Electronics mods yet!
Old May 11, 2002 | 04:30 PM
kluxman45's Avatar
kluxman45
how much oil?
well its right.7 quarts of oil with a dry oil filter.its right on the full mark.right where that hole is on the stick
Old May 24, 2002 | 06:16 PM
JIMBHAM's Avatar
JIMBHAM
how much oil?
i did the same thing. i am getting a little oil mist from the crankcase thru the valve cover, it collects in the folds of the hose to the valve body. i go in and soak up the oil with a paper towel, it amounts to less than a teaspoon full unless you are dragging the lighning then you might get more. next time i will stop at 6.5qts or 6qts like they tell you and mark the dip stick.
Old May 25, 2002 | 01:05 AM
Ratsmoker's Avatar
Ratsmoker
how much oil?
Go by what the manual says. I work at a lube rack part time and all the new ford modular motors in trucks have incorrect dipsticks. Ford says they know about it but haven't changed it for some reason.
Old May 25, 2002 | 01:53 PM
MrBSS's Avatar
MrBSS
how much oil?
[updated:LAST EDITED ON 25-May-02 AT 03:03 PM (EST)]I don't have a Lightning, but I believe all the mod motors are the same. 6 quarts (including filter) is adequate. Some of us do 6-1/2, which brings the level up to (but not over) the "max" mark. We like to have the most oil for cooling and contaminant dilution, without taking a chance that the crank will beat it into a froth.
MrBSS
P.S. Of course you've got to change the old oil hot, and make sure it has time to drain.
P.P.S. If you've got an engine oil cooler (I see they are on some Lightnings) that would probably add 1/2 quart, if you can get it fully drained.
Old May 26, 2002 | 07:51 AM
FTE Ken's Avatar
FTE Ken
how much oil?
Old Jun 2, 2002 | 09:42 PM
junehhan's Avatar
junehhan
how much oil?
I just changed the oil yesterday, and put exactly 6 quarts in there. I put 5.5 quarts, but it only filled up to the bottom add mark on the dipstick, so I just threw in the rest and now it sits in between the 2 marks. Also, something interesting, is that right after I changed the oil, my engine now makes a wierd diesel type noise while idling. It's it wierd because lots of people are having this noise pop up right after their 1st oil change.
2002 True Blue SVT Lightning
-all stock and will stay stock
Amsoil Dealer
jackfordsd350
Mar 9, 2017 01:50 PM
351Cleveland C4
Nov 8, 2015 08:50 AM
jeff gammon
Jul 30, 2012 06:19 PM
Crewcab Turbo
18
Sep 17, 2011 02:25 AM
51dueller
Jul 4, 2004 11:25 PM
