How much oil for compressor?
Old Aug 19, 2009 | 08:49 AM
jeff gammon's Avatar
jeff gammon
1978 f100, factory air, york comp. R12. How much oil for entire system?
Thanks,
Jeff
Old Aug 19, 2009 | 11:54 AM
redlightning93's Avatar
redlightning93
With the York, all the oil goes in the crankcase of the Compressor. There is a plug on the side that allows you to fill it. No oil is put in the system with this set up.
Here is some info regarding filling the crankcase:
heres how to check the oil level, if the plug on the side is visible. If vertical mount the plug is on the side, if horizontal its on top.
the valve stems, if it has a 1/4 square on each valve, need to be cranked all the way out, this seals the r12 inside the hoses. slowly remove the plug, its either 1/2 or 9/16.
make a dipstick out of mechanics wire, about 8-9 inches long.
I horizontal mount, the oil should be about 1"
if vertical, about 1 1/2", you will have to put a curve on the wire so it plumbs the bottom of the crankcase.
add as necessary, seal the plug, vacuum out the compressor for a couple minutes, then middle seat the valve stems, and you are ok, we hope.
Last edited by redlightning93; Aug 19, 2009 at 12:03 PM. Reason: Adding information
Old Jul 30, 2012 | 06:19 PM
DIRTY_D's Avatar
DIRTY_D
Thanks
Thanks for the info! Usefull.
johnsonjf
Jun 22, 2017 11:02 PM
Jeff in Ferndale Wa
Nov 23, 2016 09:46 PM
jeffie_3
13
May 21, 2016 08:59 PM
NavyLDO
Dec 18, 2015 06:37 PM
syjl
Aug 29, 2015 12:07 PM
