5.4 performance advice please?
Old Mar 25, 2009 | 01:41 AM
fordguy86's Avatar
fordguy86
i have a 1997 F-150 standard cab short bed 4x4 with a 5.4 with 190k miles. its burning a little oil, and just getting tired. i'm going to pull the motor and rebuild it, but i have a few questions, and any advice would be greatly appreciated. i have built plenty of ford 460's, but this is my first fuel injected engine build. thank you.
1- where can i get a rebuild kit? can't find one on summit racing.
2- any performance intake manifolds, cams, lifters, or pistons available?
3- what would i have to do to do bigger injectors? fuel pump or anything?
Old Mar 25, 2009 | 12:34 PM
LxMan1's Avatar
LxMan1
1) Napa perhaps? www.dssracing.com ?
2) I would upgrade heads and intake to 99-up "PI" parts. They flow better and make more power
3) No bigger fuel items needed unless you supercharge or turbo.
Old Mar 25, 2009 | 05:31 PM
fordguy86's Avatar
fordguy86
what are the "PI" parts? and can i put the cams out of a 2002 Lightning on that motor?
Old Mar 25, 2009 | 07:27 PM
Wolvrin704's Avatar
Wolvrin704
PI parts are cams, heads and intake. On the Lightning question I really don't know but I'd guess the cams are ground for a supercharged application. If thats the case they wouldn't hurt but I'm not sure they work in a NA application that well.
Old Mar 25, 2009 | 10:46 PM
fordguy86's Avatar
fordguy86
ok thanks. could i put larger injectors on it? i saw different sized ones in Summit Racing, but i'm not sure what size stock is, and how much bigger i should go.
Old Mar 26, 2009 | 08:01 AM
Johnny Langton's Avatar
Johnny Langton
They're not.They're the identical same cams used in every other 5.4L and 4.6L with PI heads.
JL
Old Mar 26, 2009 | 08:29 AM
fordguy86's Avatar
fordguy86
ok, thanks. what should i do about bigger injectors?
Old Mar 26, 2009 | 08:31 AM
Johnny Langton
Stock injectors are good for more power than you'll get a N/A 5.4L 2V to make.
JL
Old Mar 26, 2009 | 11:29 PM
Wolvrin704's Avatar
Wolvrin704
JL
Correct. Unless you put forced induction on it the stock size should be ok.
Thanks for the info on the Lightning cams. I know in aftermarket you want ones ground for that application but wasn't sure if they did it at the factory. I know more about Mustang application than I do the trucks but the motors are virtually the same.
CJude
Apr 18, 2016 05:52 AM
AZRogala
Computer Chips & Tuners
17
Dec 11, 2015 04:30 PM
digruk
Modular V8 (4.6L, 5.4L)
Feb 26, 2015 08:20 PM
Grinder Man
Oct 10, 2014 09:35 AM
TNLuke
Aug 29, 2011 09:27 PM
