Sponsored by: Real Truck
Question about 05 conversion harness relay?
Old Mar 24, 2009 | 05:49 PM
weekendwarriorfsw32's Avatar
weekendwarriorfsw32
Master of Strokes
Hello every one,
I bought the Dfuser harness the 9007 to 9008 Relay Harness and one of the relays in the kit took a dump last night where can I get one of thesis? I have never seen any like this?
Thanks
Nick
Old Mar 24, 2009 | 09:42 PM
ReAX's Avatar
ReAX
I would hope it's the standard bosch style. There is another spst that the fog light companies use. Either way, if you can't find a replacement, change it out the bosch. You can use a base, but you don't have too. I built my own and there are PNs and instructions in my tech write ups.
Old Mar 25, 2009 | 12:24 AM
DFLEX's Avatar
DFLEX
I was just on Dfusers site and found this:
"All wire harnesses (except for 9007/8 pigtails) use relays to increase voltage to your bulbs
These are equipped with 2 heavy duty relays and a fusible link for safety!
Replacement Relays are available from NAPA Part# AR350, Pilot BK 7355760"
I think the "except for 9007/8 pigtails" refers to if you buy just the pigtails which don't include any relays.
Old Mar 25, 2009 | 09:06 AM
weekendwarriorfsw32
Master of Strokes
Thank you so much!!!!
Old Nov 29, 2011 | 04:09 PM
pjk380's Avatar
pjk380
6th Gear
I have a similar aftermarket headlight harness that uses the Napa AR-350 relays on my 04 F350. The AR-350 barely lasted a year. I read others have the same problem with the AR-350's, they dont last. I searched all over for another replacement relay and ran across someone using Pilot Automotive relay, PL-RY1. I found them at Autozone and ordered a pair. So far so good, I hope they last longer than the AR-350s.
Codyg1388
Oct 8, 2015 06:01 PM
willeo6709
Aug 8, 2015 04:57 PM
Rusty_S
18
Jul 14, 2014 08:08 PM
Dasvigo
WTB - Parts & other
May 24, 2012 07:48 AM
cutlass
Oct 8, 2011 12:55 AM
