Mirror Turn Signal Lens
I saw a mirror for sale with a cracked amber lens. Maybe the dealer does not understand what I am asking for over the phone. I would think it is a pretty common breakable item.
I called the dealer and he said I needed the whole paintable back and lens at $180! I want the lens only in one of the black textured style mirrors, not the paintable style.
i bought a 2000 F350 4dr lngbed, the mirrors are towing mirrors off of a 06, the power works (i can contorl the mirrors still) but the blinkers in the mirrors doesnt work. Is it possible to get them to work? of are the 99-03 7.3's not equiped with the right wiring to make it possible. Anyoe else run into this problem or seen it done?
It is possible to get them to work. I have 06 mirrors in my 99 and I wired them up no problem. The mirror functions can have a adaptor plug installed or hard wire them. Then you just need switchable power for the heat if they are heated and tap the running lights and turn signal wires under the dash and you are good to go. Search tow mirrors and you can find a good write up. Not a big deal at all. Hope this helps. If any questions pm me and I will try to help the best I can.
NotURMailman
1999 to 2016 Super Duty
01-18-2023 06:39 AM
chaser
1978 - 1996 Big Bronco
04-21-2002 11:01 AM
