Sponsored by: Real Truck
backspacing?
Old Mar 23, 2009 | 07:20 PM
jlmotox's Avatar
jlmotox
backspacing?
what backspacing do I need for my truck?
will these work for me?
Wheel Specs:
  • Code: 1059-7970
  • Hub Centric? NO
  • Size: 17x9
  • Bolt Pattern: 8x170mm
  • Offset: -8mm
  • Backspacing: 4.625”
  • Load Capacity: 3420
  • Weight: 28
  • Center Cap P/N: 7515041
Old Mar 23, 2009 | 07:37 PM
PowerStrokeHD's Avatar
PowerStrokeHD
The backspacing is fine if your looking for wheels that stick out a bit. That particular backspacing is more ideal for a pre-'05. The '05-ups your going to want to be more along the lines of 5.5" of backspacing.
BTW... You have to be real careful of aftermarket 17" wheels when it comes to the '05-ups. Many of them will not clear the brake calipers so it is always a good idea to confirm fitment first and if possible try fitting one up before you buy...
Old Mar 23, 2009 | 07:40 PM
jlmotox's Avatar
jlmotox
yea I am looking to lift the truck 6" and was hoping the wheels will stick out a little...
is there a measurment that will tell me the if the wheels will fit around the brakes?
SteveJH
Sep 18, 2013 09:40 PM
1993 F250
Jul 1, 2011 02:32 AM
coachhomer
Mar 29, 2005 10:05 PM
raldo_gtm
Nov 2, 2004 11:37 AM
MetalSludge
2004 - 2008 F150
Jan 11, 2004 09:18 AM
