Sponsored by: Real Truck
interrior lights dont cut off
Old Mar 22, 2009 | 08:47 PM
WideOpenFord's Avatar
WideOpenFord
when i shut my doors sometimes the interrior light wont go off. also if the key is in, the door chime wont cut off when the doors shut. but some times it works fine. im guessing the switch in the door is going bad but wanted to check here first to see if its something else. thanks
Old Mar 23, 2009 | 02:18 PM
HeavyAssault's Avatar
HeavyAssault
Spray all the door latches with WD40, open and close several times, spray with WD40 again.
Old Mar 23, 2009 | 04:45 PM
dkf's Avatar
dkf
Could also be broken wires that go from the cab out through the door. Had the same issue with our explorer last week and there was a broken wire or two. Pull the boot back and check the wires out.
Old Mar 23, 2009 | 04:57 PM
RedBoat's Avatar
RedBoat
Rather Be Floatin
X2, I had to do mine every 6 months or so, The last time i used some graphite type of lubricant after the wd-40 treatment and they have been good for a little over a year.
Old Mar 23, 2009 | 08:30 PM
WideOpenFord
oh thanks yal i wall try tomorrow
