Distributor Identification?
Old Apr 1, 2003 | 07:28 PM
Racerdave's Avatar
Racerdave
I have a 77 302 in my F-100 and I am replaceing the Dizzy with a rebuilt one, I called arround the all around price is $50-$60. But one person told me I have to mesure my gear or bring it in... And I called the guys at NAPA and he said the only difference between gears is one is cast iron and one is steel? He told me to bring in my dizzy to make sure I am buying the right one, or just take it out and look and see if its cast iron? I think the one I have is steel, but am not positive it is steel? I didnt even know that they mad cast iron gears? I would think they would chew up the mateing gear (if it is steel) How can I tell? And what is best to buy? I dont want to be one of thoes guys that asks why he is geting metal shaveings in his oil filter and pull my new dizzy and find that it chew'd up my gears....
Old Apr 1, 2003 | 07:43 PM
Diesel_Dummy _'s Avatar
Diesel_Dummy _
steel gears are for OEM roller motors
Old Apr 2, 2003 | 03:10 AM
Racerdave's Avatar
Racerdave
OEM roller motor? So... what do I need? I have a 1977 302 ... F-100 shortbed.... with a am radio.... no just kidding... I just dont understand what you meen by that?
Old Apr 2, 2003 | 04:17 AM
macguyver's Avatar
macguyver
In the 80's(?) Ford started putting roller cams in the small block and they require a steel dizzy gear. The cast gear should work fine on yours.
Unless you turn the radio up too loud.
Old Apr 2, 2003 | 04:39 AM
Racerdave's Avatar
Racerdave
radio too loud? whats that have to do with anything? I have 2 Pioneer 12" subs behind the seat 400 watts a piece, and one pioneer 6" in each door and 4 tweeters in each corner... total of 800 wats and am powering it with a 650 watt phoenix gold amp. I dont understand what a gear has anything to do with my stereo?
Old Apr 2, 2003 | 05:02 AM
macguyver's Avatar
macguyver
If you've got all that behind that AM radio, I guess it wouldn't make a difference.
Old Apr 2, 2003 | 11:28 AM
TorqueKing's Avatar
TorqueKing
He's messing with you about the radio.
you have a hydraulic flat tappet cam, which is made of cast iron, therefore the distributor drive gear must also be made of cast iron. I am 103% sure of this, as I've swapped a roller motor into my '77, and had to send my distributor off to have a steel gear pressed on. Roller cams are made of billet steel, which requires the use of a steel cam gear. You cannot visually tell the difference, you have to go by how it is labled, and pull the distributor out after a few hundred miles and inspect the gear, to make sure that it is not chewed up at all. I have a cast iron gear on my desk right now that got chewed up by a billet steel cam, I"ll attach a picture of it later. Bottom line is, for your '77 motor, make sure that you get a distributor with a cast iron gear, and single vacuum advance. Should cost around $50 at Autozone, and come with a lifetime warranty. That is, of course, unless you like blasting that AM radio.....
Old Apr 2, 2003 | 01:07 PM
Racerdave's Avatar
Racerdave
lol, yeah I was just messing with you about the AM radio... lol, its a 6 dc changer with DVD player. (not jokeing) its so nice to take the girl out for a drive and then go somwhere and watch a movie "in my truck" , but yeah, thanks for the info TorqueKing it was very helpfull and exactily what I needed.
Serfbored
37
Mar 9, 2021 09:48 PM
BULLETPROOF4.9
31
Sep 6, 2017 01:41 PM
Aaron Center
Aug 4, 2017 10:21 PM
Uni61
1961 - 1963 F100 Unibody
Apr 5, 2017 10:55 PM
jlsk8ter
Feb 8, 2011 03:14 AM
