stuck intake valve
Old Mar 23, 2009 | 09:56 AM
Links_vette's Avatar
Links_vette
stuck intake valve
how would a not so mechanically knowledgable person try and correct an intake valve stuck in the open (compressed) state? I am learly of taking the head off, and those gaskets are $55 by themselves.
Some details:
-> 226 flathead
-> The push rod comes up and goes back down just fine
A friend suggested taking some "PB Blaster" penetrating fluid and spraying the valve stem and spring, then taking the plug out and putting some down the valve using the straw. His thoughts were that the penetrating fluid should break up whatever has "caught" the valve stem allowing the spring tension to slowly pull the valve back down... the physics of the concept seem right, but something about putting that stuff in the valve trane bothers me.
Old Mar 23, 2009 | 10:06 AM
bigwin56f100's Avatar
bigwin56f100
I have a complete gasket set listed on ebay # 150333961559 , It already has bids and its only $9.99.
I would pull the head and spray and try to turn the valves as well as open and close, rotate engine around and see if they stick open each time, more spray , more turn, ETC
Old Mar 23, 2009 | 12:16 PM
4tl8ford's Avatar
4tl8ford
Marvel Mystry Oil will work as well.
If you use the PB and get it broke loose I would advise changing the oil.
Old Mar 23, 2009 | 12:30 PM
bobj49f2's Avatar
bobj49f2
When I bought the V8 flat engine for my panel I had one stuck valve in each of the front cylinders. I soaked with WD-40 and tapped them down throw the spark plug hole. I alternated gently tapping down and bumping the engine over with the starter. Tool about ten minutes for each valve. Has worked fine for the last two seasons.
Old Mar 23, 2009 | 09:02 PM
ALBUQ F-1's Avatar
ALBUQ F-1
I'm partial to SeaFoam, it's like MMO but seems to be better on varnish, which is likely the problem here.
Although... could it be a mouse stuck under the valve??? (Bob, you gotta do a cartoon of a mouse's rear sticking out from under a valve head!)
Old Mar 24, 2009 | 08:11 AM
Links_vette
got 'er popped back down last night during the tornado... looking forward to redoing the compression test and hopefully its all good so i can put it all back together. I'm getting really tired of leaning over the fender.
Old Mar 24, 2009 | 10:59 AM
bobj49f2's Avatar
bobj49f2
Old Mar 24, 2009 | 11:04 AM
Glockem45's Avatar
Glockem45
Thumbs up
Oh Bob, that is some funny stuff right there. Since I recently started my 55, and hot out the mice and nesting material out the exhaust it could only be funnier if you had a cartoon that showed the mice being blown out the exhaust pipe.
Old Mar 24, 2009 | 12:55 PM
bobj49f2's Avatar
bobj49f2
You asked for it:
Old Mar 24, 2009 | 01:13 PM
Glockem45's Avatar
Glockem45
Thumbs up
Thanks so much Bob. I just saved that to my desktop. That is almost what it looked like behind my truck sunday afternoon plus all the nesting material.
Old Mar 24, 2009 | 04:15 PM
sdetweil's Avatar
sdetweil
Originally Posted by bobj49f2
You asked for it:
man!.. you have MADE my day.. !!!!!
I do so wish I had that skill.. but I AM Glad YOU do.
sam
Scratcha
Apr 13, 2017 03:49 PM
mueckster
Mar 2, 2011 02:17 PM
79FordBlake
18
Oct 6, 2009 06:36 PM
evilwayz7
2004 - 2008 F150
May 18, 2009 11:29 AM
gungho351
21
Jan 2, 2009 11:11 AM
