7.3l idi swap
Old Mar 22, 2009 | 08:58 PM
chopaz's Avatar
chopaz
7.3l idi swap
Hello, has anyone swaped in a 7.3l idi into a 73-79 f250. I have a 79 f250 crew cab 2wd short box 460 auto with 69 000miles. I have a donor 7.3l in a 83 bronco with a five spd.
Thanks Dave
Old Mar 22, 2009 | 09:32 PM
condolan's Avatar
condolan
fordcummins.com - Increase Horsepower with Ford Cummins Diesel conversion kits
Old Mar 22, 2009 | 09:42 PM
chopaz's Avatar
chopaz
7.3l idi swap
Well thats all good except I don't have a cummins I have a 7.3l diesel. Thanks anyways.
Old Mar 22, 2009 | 10:08 PM
4wydnr's Avatar
4wydnr
I know it has been done, do a search for idi swaps you might have to go back quite a ways but there were some write ups and a few pics.
Old Mar 22, 2009 | 10:12 PM
chopaz's Avatar
chopaz
7.3l idi swap
Thanks I will give it try.
Old Mar 22, 2009 | 10:21 PM
condolan's Avatar
condolan
Oh sorry! I totally wasn't thinking. I thought "diesel" and instantly thought of that link. The internet form of "speaking before thinking"... Well, if you come across a Cummins I guess...
The good news is, you could use your 460's C6 behind the diesel if you wanted to simplify the swap. I don't know how direct of a bolt-up that is though. The 460 radiator is also good to go. Plus the truck isn't 4WD, which always makes things easier.
I also recommend using the Search feature for the '73-'79 forum. I'm sure this topic has been covered before.
Good luck.
Old Mar 22, 2009 | 11:54 PM
bigblockford_390's Avatar
bigblockford_390
Make sure you post some pictures of your swap as I for one would like to see them! Good luck on your project and keep everyone posted.
Jeff
Old Mar 23, 2009 | 12:43 AM
hairyboxnoogle's Avatar
hairyboxnoogle
Working on doing this myself. Pretty much a straight foreward engine swap.
Old Mar 23, 2009 | 12:30 PM
4wydnr's Avatar
4wydnr
Good luck.
You need to do some research, the diesel and big block engines have a slightly different bellhousing. They are similar but won't bolt up. Make sure the information you give is accurate.
Old Mar 24, 2009 | 08:40 AM
chopaz's Avatar
chopaz
Thanks for all the info.
Old Mar 24, 2009 | 10:20 AM
hairyboxnoogle
The only major fab work to be done that i have run into thus far has been that you have to take the motor mount towers from your truck and the donor truck and put them together to fit the 7.3, and depending on which trans you opt to go with, you may have to build an adapter plate for the tranny mount. I havent run into anything major other than that... but i have yet to put the body back on either.
