stock tack
Old Mar 22, 2009 | 08:54 PM
Rulebreaker's Avatar
Rulebreaker
stock tack
How hard to put in a stock dash with a tack? Will the wiring be different or would it be a plug and play? RB
Old Mar 23, 2009 | 08:27 PM
Rulebreaker
I have a dash with tack out of an 89 BroncoII. It's got a cable speedo so I thought I would retain the truck speedo and use the B2 stuff. What is the chance that the wiring for a tack is there? And how many wires will need switched around? Can you get schematic's for the dash? RB
Old Mar 23, 2009 | 11:16 PM
punchrf's Avatar
punchrf
i just recently tried to put a tack gauge cluster from a 93 ford bronco into my 96 ford f250 without a tach. it made my alternator charge at 11.9 volts instead of 13.6 for some reason and threw a check engine light. however the tach was operational. don't know if that was the smartest thing ive ever done but my curiousity was going. it may be possible to change wiring pins around to make it work but its beyond me.
Old Mar 24, 2009 | 06:30 AM
Rulebreaker
I guess I'll soon know. I'm going to give it a try. RB
genevanvoorst
Aug 26, 2014 05:56 AM
39pu
1997 - 2003 F150
Mar 25, 2014 10:28 AM
genevanvoorst
Mar 1, 2014 10:23 AM
cracked block
Garage & Workshop
Oct 5, 2011 11:01 PM
mkrog
Garage & Workshop
Dec 4, 2004 12:41 PM
