Sponsored by: Real Truck
U joint grease
Old Mar 22, 2009 | 08:08 PM
6litrefan's Avatar
6litrefan
U joint grease
How do you go about lubricating u joints on the super duty's are there grease zerks???? What kind of grease????
Old Mar 22, 2009 | 08:14 PM
DAVE67FD's Avatar
DAVE67FD
I don't know what year they stopped using them but the newer ones are sealed units and not greasable. I don't think they have been installing as stock for quite some time.
Most typical non-greasable joints (no zerck fitting) are inherently stronger units. You can have spicers with zerks installed but again not as strong as the sealed units.
Old Mar 22, 2009 | 08:57 PM
6litrefan's Avatar
6litrefan
Is there anything on our trucks as far as suspension or 4 wheel drive or steering linkage? that needs to be greased???
Old Mar 22, 2009 | 09:05 PM
dstig1's Avatar
dstig1
The only grease fittings from the factory are on the U-joints for the front axle (if you have 4wd). One zerk on each, but they are tough to get at. If they stopped using them sometime after '05, I do not know, but my '05 has them, and none other.
-Dave
Old Mar 22, 2009 | 10:25 PM
6litrefan's Avatar
6litrefan
any specific type of grease need to be used?
Old Mar 22, 2009 | 10:31 PM
dstig1's Avatar
dstig1
General high pressure wheel bearing lube should be fine.
Old Mar 23, 2009 | 05:11 AM
bucci's Avatar
bucci
The u joints on the front axle still come with grease fittings. My '09 chassis cab has them.
Old Mar 23, 2009 | 06:23 AM
senix's Avatar
senix
front axle and your steering linkage
Old Mar 23, 2009 | 07:32 PM
bucci's Avatar
bucci
I didn't see any on the steering linkage. How many are there? I'll have to look better when I get it back from the upfitter.
Old Mar 24, 2009 | 05:00 AM
senix's Avatar
senix
well i will have to look myself. I know on my 06 there were at least three. haven't looked to close on my 08.
Old Apr 8, 2012 | 12:00 PM
WorkhorseF250's Avatar
WorkhorseF250
where on your 06 other then the u joints was there grease nipples? i can only find the u joints.
Old Apr 8, 2012 | 12:03 PM
senix's Avatar
senix
i sold my 06 so I cannot look at it anymore. If you looked at the axle ones that may have been it. follow the drag link and the tie rod ends if none then you got them all.
Old Apr 8, 2012 | 12:32 PM
kd0axs's Avatar
kd0axs
My 05 has them on the front axle U-Joints, but none on any of the steering parts or anywhere else.
Old Apr 8, 2012 | 03:01 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
This video covers it all.
How To: Lubricate Chassis - YouTube
Old Apr 26, 2012 | 02:55 AM
silver1's Avatar
silver1
My 01 7.3 4x4 SRW crew doesn't have fittings in the front u-uoints.im trying to decide whether or not to replace them .I'm doing some front end work and I'm thinking wile I'm in there! The universals dont seem bad now Ijust dont want to go back in, in 10 k! Question is Which ones ! I installed moog b-joints,think I'm going with national seals, but if the non greasable u-joints are stronger ,what would you use?
