What are my options? I got this truck used, and maybe it's just a wiring issue and I still just haven't found the culprit.
However, in searching the boards, I am seeing that it might not be OBD II compliant anyway? I have the 5.4, and thread I saw that on was addressing a diesel, I think.
Is there any way to address the computer other than the port beneath the dash? I am trying to track down a bad COP. If there is an easy way to do that, then I will do that and just live with the CEL.
Actually, I started with replacing the blown fuse. There is one wire that is pulled away from the bundle, light blue with a yellow stripe, that is just snipped and not connected to anything. All of the pins on the connector are accounted for and hooked up, so I am not sure what this wire is for. Ground?
I believe the 99 super duty is obd1. obd2 was light duty. my 99 reads as an obd1. it does not follow the passenger car regs - kinda like when you won't see gas mileage on the window sticker of a 3/4 ton vehicle.
