cheap 460 power?
Old Mar 22, 2009 | 12:01 AM
walkintallknls's Avatar
walkintallknls
cheap 460 power?
i have a 78 f150 factory 460 c6 it has edelbrock performer 460 intake and a 650 holley other than that its stock what can i do cheaply to bring out the beast in it i dont wanna pull the engine it runs pretty good just wanna get the most i can get on the cheap
Old Mar 22, 2009 | 12:05 AM
Bear 45/70's Avatar
Bear 45/70
Change the timing chain and gears to a pre-1972 set, which will remove the emissions retard from the cam timing in the engine.
Old Mar 22, 2009 | 12:11 AM
walkintallknls
how much gain you think ill get out of that? also i have hesitation if i punch it from dead stop...carb?
Old Mar 22, 2009 | 12:13 AM
smoke n tires's Avatar
smoke n tires
i put a set of hedman headers on mine with the pre 72 timing set and a 750 vac sec holley. also do a nice exhaust to match. my truck ran very strong with just those few things. a good rv cam would wake it up also. the hesitation is usually caused by a faulty or misadjusted acclerator pump on the carb but could be several things.
Old Mar 22, 2009 | 12:16 AM
walkintallknls
it runs like a beast now when i get past that lil stumble but i know it has more
Old Mar 22, 2009 | 12:17 AM
walkintallknls
yall got a part number for the pre 72 timing set?
Old Mar 22, 2009 | 12:22 AM
walkintallknls
also when i do the timing set swap is there anything special i need to do about resetting the timing?
Old Mar 22, 2009 | 12:43 AM
Bear 45/70's Avatar
Bear 45/70
Just go into the auto parts store and tell them you have a 1969 460 you want a timing chain for.
BigCountry1978
Dec 7, 2015 12:15 PM
Dementia
May 19, 2015 07:33 PM
Donanoyscott
1983 - 2012 Ranger & B-Series
Nov 25, 2014 10:23 PM
Dr-MorningWood
19
Nov 7, 2014 01:48 PM
300bigsix
Oct 28, 2014 05:04 AM
