jack or anyone, help please
Old Mar 21, 2009 | 07:01 PM
fordboy_52's Avatar
fordboy_52
jack,that's transfer I got from bulltet had tranny fluid in it. isn't it supposed to have 80 90 wt? please set me straight, as mine had the other.by the way, id like to know how in the hell you get it onto the jack under the vehicle, as it only weighs about 200 lbs.....thanks
Old Mar 21, 2009 | 07:57 PM
husker's Avatar
husker
Some of the newer transfers use tranny fluid. Also, to lift it check here in the tranny forum and someone has built a cradle to hold the transfer on a floor jack. Or you may have to rent a trans jack.
Second thought, a young strong bull like you should just be able to heft it up in there. LOL
Old Mar 21, 2009 | 08:11 PM
Garden Spyder's Avatar
Garden Spyder
Matt.. my transfer case is running ATF in it they said anything else was just asking for trouble.
Old Mar 21, 2009 | 08:44 PM
Garden Spyder
can you get the transfer case on the jack at all? If so could you raise the truck up high enough to get the transfer case on the jack to the center of the truck, then lower the truck back down?
Old Mar 21, 2009 | 10:12 PM
fordboy_52's Avatar
fordboy_52
I got the transfer installed. I went and bought a floor jack and lifted it on outside the truck. I couldn't believe how nice it sat on the jack with the aid of a board
tomorrow I hope to finish up and test to see if it drives.
the truck is a 76 and its a steel transfer, and I have always been told u needed 80 90. ill fill it with atf if someone tells me that is what it needs
Old Mar 21, 2009 | 10:16 PM
husker's Avatar
husker
I use gear lube in the transfer in my 78 Bronco. I think my Super Duty uses ATF fluid. If it is a 78 Ford, and the transfer is from that era, then you need gear lube.
Old Mar 21, 2009 | 10:28 PM
fordnut1985's Avatar
fordnut1985
Matt, You can go either way, if it were me, I would use ATF and a lil Lucas!!
Old Mar 21, 2009 | 10:48 PM
Garden Spyder
Congrats Matt! you got more accomplished than I have for a while!
Old Mar 21, 2009 | 11:09 PM
HappyJack's Avatar
HappyJack
I don't know. That was a chevy 205 wasn't it? I'll check with Clint tomorrow.
Old Mar 22, 2009 | 06:39 AM
Flip4ford's Avatar
Flip4ford
Jack ask Garret.. that's who he got it from... or better yet
GARRET, HERE GARRET!!! Come on!! GOOD BOY!!!! :-)
Hmm he's not posting ;quite yet???
Old Mar 22, 2009 | 07:52 AM
HappyJack's Avatar
HappyJack
Yup. It was Garretts but Clint worked on it. They should be back over here sometime late today and I'll ask them.
Old Mar 22, 2009 | 07:58 AM
fordboy_52's Avatar
fordboy_52
I am headed back out now to patch it up. I have to get on the road asap. its a combination of my transfer, garrets trans. I will just fill it with gear oil
Old Mar 22, 2009 | 10:06 AM
fordboy_52's Avatar
fordboy_52
well go figure. I broke the dam cap. its hei and I need another one. anyone have dans number?
Old Mar 22, 2009 | 10:15 AM
HappyJack's Avatar
HappyJack
I talked with Clint and he said he didn't know. He said that the 205 that Garrett has now does take the 80w90. But the t-case on the tranny you picked up is a 203. Might search on line.
Old Mar 22, 2009 | 10:21 AM
HappyJack's Avatar
HappyJack
Ok. I checked on line and found this: New Process 203 Transfer Case Tech - Trucks 4x4 @ Off-Road.com
That says if you have a 203 t-case you need to put 10w40 engine oil in it.
