460 blow by issues
Old Mar 21, 2009 | 06:45 PM
datkisson's Avatar
datkisson
460 blow by issues
I have a 73' F250 camper special with a 460 in it. At high revs I keep blowing out my PCV valve, and oil is lifting up my dip stick about 3/4 to 1 inch and throwing oil all over my engine. I have an aftermarket Carter performance 4 barrel card and intake on it, and I've been working on getting the timing just right. It just doesn't perform like I know it can. I've had several people tell me that I have blown piston rings and that I should do a compression test (which I plan on doing of course), but I have very limited experience with auto mechanics and if any body out there has any suggestions or advice, I would greatly appreciate it! Thanks
Old Mar 21, 2009 | 07:18 PM
Bvis75's Avatar
Bvis75
I was gunna say Rings also. Had a 390 do the same thing, #4 cyl was dead
Old Mar 21, 2009 | 07:21 PM
skunktruck's Avatar
skunktruck
it does sound like its getting air presure from somewere.....
Old Mar 21, 2009 | 07:24 PM
skunktruck's Avatar
skunktruck
roughly at what RPM?
Old Mar 21, 2009 | 08:18 PM
fmc400's Avatar
fmc400
MSEE
Sounds like piston rings, try a wet and dry compression test and I can almost guarantee you your wet compression will be higher.
Old Mar 21, 2009 | 09:47 PM
datkisson's Avatar
datkisson
I'm not sure what the rpm range is when it starts blowing because I don't have a working tachometer on it, but it seems like it's when I really get on it that it starts having issues. Thanks for all the reply's so far!
What does it mean if the wet compression is higher?
Old Mar 22, 2009 | 08:42 AM
427 fordman's Avatar
427 fordman
If you have limited mechanical knowledge get a compression tester(or borrow from a friend), take all plugs out and test each cylinder. If you get a new one directions are easy to follow. If you borrow one whoever you borrow it from will tell you how to do it. I give it a 95% chance of at least one bad cylinder.
j250hd
17
Apr 18, 2013 01:34 PM
a500ponies
Jul 11, 2011 01:03 AM
F-250 WARHORSE
126
Jan 11, 2011 06:59 PM
97F350PowerStroke
Jan 29, 2007 09:55 PM
95ford250_460
Jan 11, 2005 03:35 AM
