Excursion 4x4 issues
Old Sep 4, 2012 | 09:00 PM
chaso2's Avatar
chaso2
I have 2002 Excursion V10 4x4.
4x4 does not work it has the following pt codes.
P1876 2wd Solenoid Fault
P1828 T-Case CCW Shift Relay Fault
P1832 T-Case Differential lockup solenoid fault
P1865 -?
P1820 T-Case CW Shift Relay Fault
B1342 Faulty control module
Does the failure of any one of these cause a cascading effect. If so which one should be replaced first.
Old Sep 5, 2012 | 01:00 AM
Monsta's Avatar
Monsta
Sit. Stay.
Personally I'd suspect the control module. But I'd check all the connections and relays first.
roycephus_18
Dec 23, 2015 10:38 PM
429crossbolt
1983 - 2012 Ranger & B-Series
Feb 1, 2006 08:49 PM
shipwreck17
34
Jan 4, 2005 12:05 PM
yoohooman480
Jan 16, 2004 07:44 AM
