DP Tuner install question
Old Mar 21, 2009 | 10:59 AM
robs01f250's Avatar
robs01f250
go ahead and check your batteries and take another look at the fuses under the dash and under the hood and see if yu can tell anything
Old Mar 21, 2009 | 11:09 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
The PCM will not cause none of the lights to come on. More then likely it's like was just said, a fuse. Are you making sure the PCM connector on the firewall is in all the way? I have seen where some have not had that connection in all the way, and had some problems.
Old Mar 21, 2009 | 12:33 PM
ghig1967's Avatar
ghig1967
Ok, I am at wits end here.. I took out the PC, tried cleaning the contacts again, re-installed & still nothing. I have the battery charger on, even though the batteries show 12+ volts with a meter. The headlights work, the chime works with the key, the interior lights work, turn signals. No lights on the instrument cluster come on when I turn the key, & the radio does not work. I have looked over all the fuses, even pulling out the smaller ones to check & can't find anything. I called Jody, his answering machine said he is in Washington live tuning until tuesday & I also sent an e-mail to him as well as ITP diesel who I bought it thru... I'm running out of ideas....
Old Mar 21, 2009 | 12:55 PM
miller_feed
Look at fuse #19 under the dash. It is a 10a fuse that does the cluster and PCM. See if this works. Click here
Look on page 172 and 173
Old Mar 21, 2009 | 01:02 PM
megawatt00's Avatar
megawatt00
Double check these fuses in the cab fuse box
#15 5A
Stop Lamp Switch (Logic): Generic
Electronic Module (GEM), Powertrain
Control Module (PCM), Four Wheel
Anti-lock Brake System (4WABS) Module,
Brake Shift Interlock, Cluster and PCM
Keep Alive Memory
#16 15A
Instrument Cluster, Hi-beam Headlamps
#19 10A
Auxiliary Powertrain Control Module
(APCM) (Diesel only), Instrument Cluster,
GEM Module, Overdrive Cancel Switch,
Idle Validation Switch (Diesel only),
Overhead Console, Diesel PCM via Clutch
#29 5A
Instrument Cluster (Charge and Airbag
Warning Lamps)
#30 30A PCM Relay Coil, Ignition Coil (Gasoline
only), Fuel Heater (Diesel only),
Wastegate Solenoid (Diesel only), Injector
Driver Module Relay Coil (Diesel only)
Old Mar 21, 2009 | 01:10 PM
ghig1967's Avatar
ghig1967
Ok, i'll go double check them again.. Diane answered my e-mail & I responded back.. maybe she or you guys can answer some of my questions. In the No Start mode.. does it do the things I have occurring when you turn the key? No dash lights, or radio? If so, is it possible the PCM was stuck in no start mode even after I took the chip out or does it automatically revert back to stock once its unplugged? I'm just wondering if this is PCM/Tuner related now or is this something else like fuse/relay ??
Old Mar 21, 2009 | 01:14 PM
miller_feed
The pcm should go back to stock when you take the chip off. To me it seems like a fuse problem. I have yet to put my chip in the no start mode, so I can't help with that question.
Old Mar 21, 2009 | 02:56 PM
ghig1967's Avatar
ghig1967
Checked all the fuses, still no luck.. I've had this thing in & out enough times I can do it in my sleep.. Anyone know, would a fried PCM cause problems i'm having? everything dead with the key other than the chime, no radio either?
Old Mar 21, 2009 | 05:49 PM
miller_feed
Gregg, sorry, I am out of ideas. I think Jody needs to get with you and figure this out. Wish I had more help for you.
Old Mar 21, 2009 | 06:06 PM
ghig1967's Avatar
ghig1967
Thanks Rick. I'm beginning to think something is wrong with the PCM or maybe something else. I got it to crank & the dash lights work again, but with or without the DP Tuner, it won't start. It cranks, builds up oil pressure, but the tach doesn't move & it won't fire.. no smoke from the tailpipe either.
I'm about to give up for the day, I can't figure this out & it will be dark outside soon. Thanks again everyone for the help, I spoke to Jim (megawatt) on the phone earlier & he gave me some new ideas to try. I thought i was getting somewhere when I got it to fire....
Kinda sucks, I've been excited waiting for the Tuner to get here for over a week & now that its here, this is ruining the excitement..lol
Old Mar 21, 2009 | 06:37 PM
MADVAN's Avatar
MADVAN
Did you check the pins on the pcm and connector?(harness)
Security system?
Just thoughts.
Bill
Old Mar 22, 2009 | 08:24 AM
ghig1967's Avatar
ghig1967
Security system?
Just thoughts.
Bill
Yes, I checked the connectors & pins & I have no security system, just a remote starter. I spoke to dennis @ ITP diesel & he suggested i borrow a PCS & swap it without the tuner & see if the truck starts... He is also thinking it may be a CPS since it cranks & the tach doesn't move.
Old Mar 22, 2009 | 08:32 AM
  #28
MADVAN's Avatar
MADVAN
Possible static electricity when you cleaned the IC Board?
S.E. could takeout the PCM.
Bill
Old Mar 22, 2009 | 08:39 AM
  #29
ghig1967's Avatar
ghig1967
I have no idea what happened at this point. I read where you don't use anything metal, so I only used my fingernail & a scothbrite scrubby.. Now its gonna be trial & error seeing what I can do to get it to start. Unfortunately I am out my vehicle & have to go to work today.
Old Mar 22, 2009 | 09:01 AM
  #30
miller_feed
The CPS could have gone bad. My tack does move when I crank on it.
