Zf-6
Old Mar 20, 2009 | 08:14 PM
kaotikedge_111100's Avatar
kaotikedge_111100
Zf-6
Hey guys, I was hoping someone could confirm that a zf-6 from an 01' superduty 7.3L powerstroke will bolt up to the IDI block.
If it does I am getting a complete powertrain from tranny to xfercase and driveshafts. I will make sure to post a thread on the install with tons of pictures.
-Mike
Old Mar 20, 2009 | 08:29 PM
George D.'s Avatar
George D.
yeah the 7.3 powerstroke and IDI have the same trans bolt paattern.
Old Mar 20, 2009 | 08:33 PM
1994diesel's Avatar
1994diesel
cool, i was just day dreaming about this today. i saw a superduty 7.3L powerstroke with a 6spd at the junk yard today, i forgot to check what year but it definatly was a younger than a 99
Old Mar 20, 2009 | 10:04 PM
Dean88's Avatar
Dean88
If its younger than a 99, then its gonna have the ZF-5
Old Mar 20, 2009 | 10:08 PM
George D.'s Avatar
George D.
Still would be cool though
Old Mar 20, 2009 | 10:10 PM
Dean88's Avatar
Dean88
It is cool, except for one slight problem, they won't work with your Tcase (if its a 4x4) due to a larger output shaft. Also the ZF-6 has no provision for a speedo sensor.
Old Mar 20, 2009 | 10:28 PM
kaotikedge_111100
I am getting the transfer case with the zf6. It is a manual shift xfer case too so there is no dicking around with electronics.
I will be taking off the cab and fabricating all new mounting brackets and crossmembers to make it work like it should. I don't imagine it being very difficult as long as it bolts up to the IDI.
The guy i'm purchasing it from will have it pulled out late next week. I will make sure that I take tons of pictures and make lots of posts here.
Old Mar 20, 2009 | 10:30 PM
kaotikedge_111100
And for the speedo problem I will just order an Autometer electronic speedometer or just continue to drive off the tach...like i've done since I got the truck.
Dean88's Avatar
Dean88
The only problem you are gonna have is NO speedo, your truck has the speedo in the tranny (I think, I've never worked on a 4x4 in one of these trucks), but the 99+ have the speedo sensor in the rearend.
I say just get a GPS system and they'll tell you your speed, or you can be like me and just learn the RPMs vs speed.
dyoung14's Avatar
dyoung14
but he can use the transfer case from the super duty, but he will have to come up with something for a speedo
Old Mar 20, 2009 | 10:32 PM
Dean88's Avatar
Dean88
As long has he uses the tranny and Tcase from the Sduty, then it can be made to fit.
Old Mar 20, 2009 | 10:33 PM
dyoung14's Avatar
dyoung14
wow in the time it took me to post that 3 other people had already posted lol
Old Mar 20, 2009 | 10:35 PM
Dean88's Avatar
Dean88
I know, its kinda wierd, it makes things seem quite redundent being is we all said the same thing, just in different order, but hey its real nice to see things are lively around here.
Old Mar 20, 2009 | 10:41 PM
kaotikedge_111100
wow, never had a thread before that got so many hits in 5 minutes!! The speedometer is the last of my worries, do any of us actually use it anyway??
My truck doesn't have a working speedometer in it right now anyways, never has since i've owned it. I drive off the tach and sound of the engine...
I'm in the middle of a D60 swap with F350 springs right now and just ordered all new gauges....this old truck is getting a lot of new cool parts.
Old Mar 20, 2009 | 10:44 PM
Dean88's Avatar
Dean88
Kaot, I know the feelin, my truck doesn't have a speedo either, but I do know most my RPMs and speeds.
It def sounds like you've got quite the operation goin on, I take it your working on teh 79?
