7.3 sensor problem in cold weath
Old Mar 20, 2009 | 04:14 PM
RussellFord's Avatar
RussellFord
4wd Low
Hello forum!
I have a 2002, Excursion with a 7.3L and 153,000 miles. The truck is a champ, but this last snow-fall two weeks ago, I'd say it was about 30 degrees, the truck wouldn't go over 30 MPH initially, then as it warmed up it wouldn't go over 45 then finally when the engine was at operating temperature it ran normally. It ran normally after it reached standard operating temperature.
I suspect a sensor needs to be replaced, but before I took it into Ford I figured I would check with you guys first.
Thanks,
Russell
Old Mar 20, 2009 | 04:34 PM
Smokin''s Avatar
Smokin'
Smokin
Hi Russell,
Welcome to FTE.
These trucks hold a lot of oil, and performance tends to suffer when they are cold..it takes a while to get all of that cold oil warmed up and circulated.
That being said, what you describe is not normal...but I would suspect oil level first before going into anything else. What does your oil look like, and have you changed it since you bought the truck?
Have you changed your fuel filter lately? In cold weather, depending on the quality of fuel, untreated fuel can freeze, sometimes causing fuel restrictions through the fuel filter and various other places.
Also any Service Engine Soon light? Or is the OD light flashing on the column shift?
Old Mar 20, 2009 | 04:40 PM
RussellFord
4wd Low
Originally Posted by Smokin'
Hi Russell,
Welcome to FTE.
1. No service engine light has come on.
2. In January, I had a major service done to the truck: New fuel and air filter, all fluids checked, etc.
3. I've had this truck for 4 years and have driven it in much colder weather than what occured earlier this month. I change the oil in her every 3000-4000 miles. She's babied.
4. You are correct that it may have been the fuel. I will check how she runs next time I'm with her.
Old Mar 20, 2009 | 04:47 PM
Ponyboychris's Avatar
Ponyboychris
Welcome Russell,
Lisa's got you going in the right direction. I thought of one other thing. In the cold, our trucks have an EBPV (Exhaust Back Pressure Valve) that closes and puts a temporary load on the engine to get it to warm up quicker. If you take off with this valve still closed, then your truck will act like its dragging an anchor behind it. I know if I try to leave on a real cold day - in the single digits - without letting the truck warm up for a few minutes, it will act that way. 30 degrees it shouldn't be very sluggish over a few minutes or so. Just thinking out loud.
Here's another thread with some good tips on cold weather operation:
https://www.ford-trucks.com/forums/4...ke-thread.html
Old Mar 20, 2009 | 04:51 PM
RussellFord
4wd Low
Originally Posted by Ponyboychris
Welcome Russell,
Thank you PonyBoy for the link.
The problem is that something different has occured, way out of the norm, and that is indicative of a problem that goes beyond just letting the vehicle warm up for a few minutes.
It felt like either the engine wouldn't rev high or that said rev's would be translated to the transmission.
Now I may be wrong, but either some temp sensative valve isn't working properly, or come chip has been adversely affected by the temp.
Who knows, you guys may be correct, it's just that I've never seen that problem before.
Old Mar 20, 2009 | 04:53 PM
Smokin''s Avatar
Smokin'
Smokin
Sorry Russell. When I see a new member I automatically assume the truck is new, or new to them.
Welcome Russell,
Hmm...have there ever been cases when an EBPV sticks on even after throttle is applied? That'd definitely be interesting.
Old Mar 20, 2009 | 04:55 PM
RussellFord
4wd Low
No need to apologize, just passing along the information. I should have stated as such in the initial post.
Old Mar 20, 2009 | 06:06 PM
piotrsko's Avatar
piotrsko
Kwikordead had that i believe, just before he wired his open.
Old Mar 20, 2009 | 06:28 PM
Ponyboychris
OK, keep the info coming our way. Is the truck stock or do you have any mods that have been done? Tuner, chips etc?
Old Mar 20, 2009 | 06:30 PM
Pocket's Avatar
Pocket
Russell, you need to clean out the exhaust backpressure sensor.
This sensor is key to proper operation and function of the exhaust backpressure valve, and works to provide the PCM with information on the amount of backpressure generated. In response the PCM will adjust the opening and closing of the valve until the engine reaches operating temperatures.
The exhaust backpressure sensor is located on the front of the engine just behind the idler pully. Under the sensor is a steel tube that leads to the front of the passenger's side manifold. This steel tube gets clogged with soot, and plugs the tube preventing the sensor from reading the backpressure. If the sensor can't see higher backpressure, the valve will stay closed even when accelerating. The problem goes away once the engine oil is up to operating temperatures (over 160 something degrees). This is why you can't get up to speed, and also why the truck runs normal once it's up to operating temps.
Here is a link to a guide that will help you clean out that sensor tube: http://www.guzzle7pt3.com/ebps
Old Mar 20, 2009 | 07:13 PM
RussellFord
4wd Low
Mr. Pocket, thank you so much.
I'll be with the truck in a little less than 3 weeks and I'll let you and everyone else know how it works out.
Thank you again!
Old Mar 20, 2009 | 10:29 PM
Presa C's Avatar
Presa C
"Or is the OD light flashing on the column shift? "
Hi Guys , just curious to know what the overdrive light flashing or coming on means.
Thanks
Old Mar 20, 2009 | 11:46 PM
Smokin''s Avatar
Smokin'
Smokin
Curtis, I am going to start calling you Mr. Pocket now.
Thanks
Generally, if there is a problem with the transmission, TC, or Vehicle Speed Sensor, the truck will set off a code which causes the OD light to flash.
Old Mar 21, 2009 | 12:20 AM
adamzelazowski's Avatar
adamzelazowski
OK when my valve cover conector been disconect check engine light flashing and OD.This causing same truck sometimes driving 30mph and sometimes running good.When is cold plastic take shorter and engine warm up plastic expound then pop out.Check any codes.
Old Mar 21, 2009 | 12:25 AM
Presa C's Avatar
Presa C
Thanks Lisa, that makes a lot of sense to me now. i haven't been using my truck my dad has and was saying the OD light came on and when i used my evolution the other day i got a code for the VSS.
I love this detective work and i must say a big thank you to everyone for your knowledge and help. I had my truck at a local ford dealer here in montreal , Quebec and they didn't figure things out on my truck.
you are all a God send!!!!
Bobbi
