Sponsored by: Real Truck
Rotor Removal help
Old Mar 20, 2009 | 02:20 PM
freejack013's Avatar
freejack013
Rotor Removal help
Hello, I need help before I break something. I have a 1999 F350 7.3l crew cab pickup. I need new rotors on all four I have started in the rear. I have pulled the tires and calipers/brakes. Next I need info on how the rotor is removed from the truck> I have pulled out the axle already. What I think is there is a bearing threaded on that hold the rotor/hub assembly on. If I am correct what is needed to remove that? is there any special tools I will be needing for this? let me know please. I need the truck back on the road soon.
Old Mar 20, 2009 | 02:24 PM
antony25's Avatar
antony25
There is a special socket used to remove the wheel bearing nut. The rotor bolts on from the back.
Old Mar 20, 2009 | 02:46 PM
03_PSD's Avatar
03_PSD
no special tool, sounds like the rotor might be rusted on. try spraying it with a penatrating oil of some sort, let it soak. if that don't work try hitting the rotor with a hammer or something.
Old Mar 20, 2009 | 02:48 PM
03_PSD's Avatar
03_PSD
here check these articles out for help:
https://www.ford-trucks.com/article/...e__Part_I.html
and
this one really helps with the rears...
https://www.ford-trucks.com/article/...__Part_II.html
Old Mar 20, 2009 | 02:50 PM
03_PSD's Avatar
03_PSD
is your truck single rear wheel or dual rear wheels?
Old Mar 20, 2009 | 03:00 PM
freejack013
thank you, any chance you know how to get the rotor off the axle housing.
Pictures of where I am:
Old Mar 20, 2009 | 03:04 PM
freejack013
Dually 1999
Old Mar 20, 2009 | 03:59 PM
freejack013
Hey alright got it remove and 1 replaced. Thank you all for the assistance maybe some day I can help some else out. Pat in RI
Old Mar 20, 2009 | 04:01 PM
freejack013
for Future people trying this that lock ring come off by tapping lightly the ring until the assembly comes off and the whole rotor slips off. also there may be a wedge lodged in the top key slot. ( I have been told) there was none there on mine.
Old Mar 23, 2009 | 07:17 AM
03_PSD's Avatar
03_PSD
I actually replace all rotors and pads Saturday also. The rears were a pain in the @$$ to get off. One thing I think really helped out was to spray penatrating oil on the rotors, they were frozen or rusted on. Then pounded the rotor while turning it, then it slid right off.
Glad you got yours off.
EXbowtieguy
Mar 23, 2025 12:29 PM
jdgreen72
Oct 31, 2007 12:18 PM
kawika
Apr 14, 2007 08:52 AM
ayse
1978 - 1996 Big Bronco
Aug 15, 2006 01:30 AM
purplegoat
Mar 24, 2004 10:59 PM
