1978 - 1996 Big Bronco
Removing rotors
Old Aug 14, 2006 | 01:57 AM
ayse's Avatar
ayse
Removing rotors
I have a '90 Bronco 351 with manual hubs and i am trying to replace the rotors. The question i have is, after I remove to 2 retainer rings and pull the body assembly out should the rotor just pull right off? Do I need a speacial puller for this? I have the rings off but the rotor won't pull off, I don't know if there's some kind of trick that anyone might have.
Thanks for your help
Old Aug 14, 2006 | 06:37 AM
jem270's Avatar
jem270
I have never taken mine apart but I have been told that you just pound them apart. I think I would just buy the whole rotor/hub assembly.
1988 EB Bronco - 302 - AOD - 3.55 Lim Slip 8.8- Manual Hubs and Transfer Case - BFG 32/11.5 AT - 209,000 miles
Old Aug 14, 2006 | 08:53 AM
poffutt's Avatar
poffutt
No! you need a special tool for unbolting the rotor. The tool can be bought form the parts store (less than $20). It is a big Half inch socket that has 4 prongs that will slide on to your rotor while it is on the spindle Then just unbolt just like any nut with a ratchet. Jem270 is talking about after you get them off. If you buy new ones you may have to split the Hub and rotor assemble. I did this, Just put some old lug nuts on the bolts and pound them out. to put them back together just use an impact wrench and tightem them down untill the lug bolts are flush.
Old Aug 14, 2006 | 09:05 AM
HUCKSTER-USA's Avatar
HUCKSTER-USA
yep poffutt hit the nail right on the head! if you have big needle nose pliers open it up stick each end into opposite notch, get a good bite, then try to loosen, these shouldn't be too tight
Old Aug 14, 2006 | 11:24 AM
ayse's Avatar
ayse
I guess it's that wrench that i need to get, just looking around on the site i think it's called a spanner wrench. I already have the rotor hub assembly, Thanks for you help. I'll let you know how it goes.
Old Aug 14, 2006 | 12:50 PM
djjoshuad's Avatar
djjoshuad
I tried to reply with a link to an external site... one that has a detailed step-by-step of how to do this... but it never made it to the thread. I'll see if I can PM it to you.
Old Aug 15, 2006 | 01:30 AM
greystreak92's Avatar
greystreak92
Ayse,
Welcome to FTE and the Big Bronco Forum. The folks here know their stuff. They have steered you in the right direction. (no pun intended)
EXbowtieguy
Mar 23, 2025 12:29 PM
AlSwope
Nov 8, 2016 10:38 AM
NorthwoodGuy
Nov 11, 2013 07:49 PM
61 uni
Jun 21, 2009 09:28 PM
lydell
Sep 6, 2003 06:31 PM
