Upfitter Switch high idle questions
Old 03-19-2009, 10:48 PM
southbound35west's Avatar
southbound35west
southbound35west is offline
Question Upfitter Switch high idle questions
hello again every one...............i have a 2006 , 6.o and i am trying to install my upfitter switch kit i just got, i have read all of the instructions in the tech folder and from other websites and they all say the same thing...........i have got it all installed, i am trying to hook up my high idle modification, the istructions say use the orange and light blue wire from the harness end and then hook it to the purple and light green wire from the customer access bundle..................my upfitter wiring harness has 2 orange and blue striped wires, one big and one little, which one do i use? which # will the high idle switch be?..........................i found the customer access bundle and it has a purple wire with a green stripe and a green wire with a purple stripe, which one of these do i hook the orange and blue to for the high idle mod?.....................thanks for any help on this issue.
Old 03-20-2009, 08:56 AM
SteveBricks's Avatar
SteveBricks
SteveBricks is offline
You should use either #3 or #4 - the high idle does not draw high amperage, so there's no need to put it on #1 or #2.
Purple/w Green stripe to the thinner Orange/Blue stripe
Old 03-20-2009, 09:02 AM
southbound35west
that is what i thought, just wanted to confirm it on here...........thanks for the help steve.
electric_jimmer
05-28-2012 05:31 PM
Rayvin55
1999 to 2016 Super Duty
04-13-2011 05:30 AM
zitman11
03-21-2010 03:16 PM
RangerJoe
03-29-2002 01:41 PM
Quick Reply: Upfitter Switch high idle questions
