Sponsored by: Auxito
High Mileage?
Old Mar 19, 2009 | 07:28 PM
Bruker's Avatar
Bruker
Question High Mileage?
I'm thinking of getting a 2001-2003 F-150 4x4 and it'll probably have around 100,000+ miles on it. What kind of problems are common with the 4.6 & 5.4 engines with that many miles?
Old Mar 19, 2009 | 08:36 PM
steve(ill)'s Avatar
steve(ill)
i bought a 2001 5.4 with 125k miles, 3 years ago.
--all filters and oil for trans/ motor/ axles and fuel filter at 125k
--lower ball joints at 126k
---spark plugs at 130k (recommended at 100k).
---3 COPS between 140 and 180K
-- upper ball joints at 150k
--alternator at 150k
---brakes at 160k and front discs
---drive shaft universals and battery new when i bought it at 125k.
KingRanchMan02's Avatar
KingRanchMan02
Honestly with that kind of mileage, the truck is just getting broken in. Good luck!
Old Mar 19, 2009 | 09:21 PM
fbodyfan's Avatar
fbodyfan
Had my intake manifold crack at 115k
Fuel pump went at 120k.
Just got done putting rotors and pads all around at 124k. Done several times.
Thats the extent of the work, had it since 45k
Old Mar 19, 2009 | 10:11 PM
galaxie641's Avatar
galaxie641
100K miles is nothing on these engines as long as they have been maintained.
Old Mar 19, 2009 | 10:57 PM
fireball 440's Avatar
fireball 440
exactly right. Look for things like brakes, axle seals, altenator, u joints, ball joints, tie rod ends, spark plugs, COPs, and change all the fluids.
Old Mar 20, 2009 | 09:51 PM
19fifty4's Avatar
19fifty4
I had to replace the coil at 125K. That's it as far as engine related issues. Everything else has been maintenance and consumables. You should have many more miles to enjoy your new truck.
Old Mar 21, 2009 | 12:13 AM
rambaseball45's Avatar
rambaseball45
my 1997 4.6 liter has 200,000 plus miles on it and the ONLY thing i have had to fix on it was one of my pulley's came loose which made it get out of line and it started ripping my belt. i tightened it back up and no problems sence. i change my oil every 3,000 miles too. just look for one that seems to be well maintained. the 4.6 is arguably the most reliable engine ford built IMO so you cant go wrong with it
Old Mar 22, 2009 | 06:58 PM
mtyost's Avatar
mtyost
My 97 has 211,000 on the 4.6, it has only had regular maintenance preformed on it and it runs amazing.
Old Mar 22, 2009 | 10:21 PM
Club Wagon's Avatar
Club Wagon
Many complain about noisy exhaust manifolds b/c of warping, cracking & the studs rotting out. Not sure what year FORD finally improved the aluminum heads in response to the dreaded stripped threads/blown out spark plug mess. Unless antifreeze was changed regularly head gaskets become vulnerable & are costly to replace.
A friend, who is a career mechanic, had his bought new '01 5.4 drop a valve's retainers & eat the valve, totaling the V8 at 125K. This put him in the position of rolling the dice on a salvage replacement motor. The 100K mark also means stuff like AC compressor, water pump, alternator, plus frontend joints & major brake components will likely need attention soon.
In OH I'd be very concerned about rust.
Old Mar 23, 2009 | 11:02 AM
MIKE 04 GT's Avatar
MIKE 04 GT
My truck has 209,xxx and only had oil changes and tune up, and tires untill 205,xxx and had to change the alternater.
