breakaway battery
Old Jan 5, 2003 | 09:00 AM
ford_nut's Avatar
ford_nut
breakaway battery
Guys
I was looking over my setup here and I noticed that I need to charge my breakaway battery? I dont have the charger wired in. My tow place said that they can wire a 'trickle' charger? for an additional $80.00 Is this charger really necessary and if so, can I do it myself? Ive seen kits on the net that have the breakway switch battery and charger but I dont have a charger with my setup I dont understand why they would put the switch and battery but no charger! How big is the charger anyhow? is it 12 volt? Is it inside that box with the battery? I dont want to go taking stuff apart here--ESPECIALLY on a NEW trailer!
Old Jan 5, 2003 | 09:04 AM
ford_nut's Avatar
ford_nut
breakaway battery
I made a boo boo with the above post! I meant to say, 'I dont think that I have a charger wired in...' Sorry for the confusion!
Old Jan 5, 2003 | 09:28 AM
jim henderson's Avatar
jim henderson
breakaway battery
Hmm, I assume you are talking about the battery that powers the emergency brake feature on trailer brakes that applies power if your trailer gets disconnected from your truck during a tow.
Kind of odd, unless your trailer is a home brew(so who knows what ya got), most trailers with batteries will charge thru the electrical connection to the truck. If you have a travel trailer, it will also charge thru the AC converter.
If it is a home brew or for some strange reason you don't have a charge connection, then I guess you can wire one up easily enough. You can get the parts from most trailer supply stores and it shouldn't take much work. Only gotcha is whether the electrical system on the trailer is homebrewed and kludged up. If you have 12v power with enough current capacity at the connector you could be as simple as a heavy gauge wire to the battery or you mightneed a disconnect to prevent draining the truck battery when shut off.
Good Luck,
Jim Henderson
Old Jan 5, 2003 | 10:04 AM
horsepuller's Avatar
horsepuller
FTE Leadership Emeritus
FTE Emeritus
breakaway battery
It might be a 12v dry cell disposable battery. That's what I have on my trailer.
You're probably gonna have to open the battery box and peek inside.
Old Jan 5, 2003 | 11:25 AM
jschira's Avatar
jschira
breakaway battery
The battery should charge while towing. The problem is, when you first tow in the Spring, after the trailer has been sitting for 3-4 months and not hooked up. I took my battery out and put it on my auto battery charger overnight, the put it back in my trailer.
Old Jan 5, 2003 | 02:51 PM
charlez's Avatar
charlez
breakaway battery
I purchased a new trailer with a Tekonsha Break Away Kit. It didn't come with a charger and does not charge off the tow vehicle. The dealer just said to charge it once in a while (every couple months?) with a trickle charger to top it off. You really never use the battery so just make sure it's topped off every once and a while.
Old Jan 5, 2003 | 03:41 PM
aldridgec's Avatar
aldridgec
breakaway battery
The small battery used for the breakaway should not be on a regular charging circuit as it is not normally drained. It should be checked regularly for operation, as well as the rest of the brakes by jacking up at least one brake operated wheel and spinning it and pulling the breakaway switch out, or by pulling the switch and trying to drag the trailer. This will check that the braked wheels work and that the breakaway battery circuit works. These batteries can be put on a house charger every now and then (maybe bi yearly?) to keep them up to snuff, but nothing should really be neccesary besides replacment every couple of years.
Remember, if you have a factory ford 7 pin trailer harness, you already have a switched 30 amp battery supply in the connector. The diagram on the cover will show you which one it is. However, you may need to add a relay to the fuse box under the hood to activate this circuit.
Chris
Old Jan 5, 2003 | 05:48 PM
jschira's Avatar
jschira
breakaway battery
I just checked my '03 X with the factory tow package. There is a 20 amp fuse (#115) and a 30 amp relay (#305) both labeled "battery charge tow" or something like that.
Old Jan 5, 2003 | 07:03 PM
aldridgec's Avatar
aldridgec
breakaway battery
Hmm, sorry, I remembered the 30amp relay, thinking 30 amp fuse. The fuse feeds the relay, and the relay switches the fuse to the socket only when the ignition is on.
Old Jan 6, 2003 | 10:46 PM
ford_nut's Avatar
ford_nut
breakaway battery
Guys
i just eyeballed the wiring more closely on my trailer. Seems like I dont have a charger hooked to breakaway circuit. I have 2 wires coming out of the breakaway--a blue and a white. The schematic shows the white as a ground and the blue goes to the brake controller. The installer DID put a 7 pin connector in. Basically, He tied it in with my existing 6 pin. I dont think that I am going to bother with a charger setup because I dont feel like ripping apart all the neat wiring just to find that 'switched' or 'auxillary' 12 V power suppy.!
Thanks again for all your help!
regards
Ben
Old Jan 8, 2003 | 08:30 AM
castines's Avatar
castines
breakaway battery
omni
Electrical Systems/Wiring
Nov 18, 2014 05:28 PM
berick
Feb 15, 2014 06:28 PM
jomac11
All Things Towing
Feb 3, 2009 08:59 PM
DST
Jan 12, 2009 10:56 PM
maevans
Garage & Workshop
Mar 29, 2006 04:47 PM
