spring over vs spring under
Old Jan 5, 2003 | 04:56 PM
johnsdiesel's Avatar
johnsdiesel
Old Jan 6, 2003 | 10:39 PM
ford_nut's Avatar
ford_nut
guys
can anyone advise whether it matters if a trailer is spring over or spring under? My dad just saw my new purchase and he said that I made a mistake by buying a spring under setup. His rationale was that spring unders carry less weight than spring overs? Now Im starting to second guess my purchase
regards
Ben
Old Jan 6, 2003 | 10:49 PM
Kenworth's Avatar
Kenworth
It is true spring unders don't carry as much weight because you are hanging the trailer from its axle with U bolts where spring over you have more strength. The big draw back is with spring over you gain extra height which you may or maynot like depending on the purpose what is this trailer gonna be used for and whats its carrying capacity.
You could always convert your trailer to spring over you may only have to change the springs and put new perches on the axle but if we knew what this trailer is for then we can give you some better opinions.
Old Jan 9, 2003 | 09:12 PM
RichF350V10's Avatar
RichF350V10
Does your trailer carry the weight that it was designed and advertised to carry? If yes and that is what you want then the axle-spring configuration makes no difference.
Trailer designers can design thick enough metal to "hang" the load vs. sit the load on top of an axle. Where the axle is placed is a ride heigth issue.
RichF350V10
Old Jan 10, 2003 | 09:06 AM
Buckarcher's Avatar
Buckarcher
I agree with Rich, I saw your other posts before you bought your trailer and it sounded like you got as much trailer as you wanted to get. You looked at several, this is rated to hold enough weight, and I'm sure you noticed the deck height when you bought it. What difference does it make where the parts are as long as you're happy with the quality?
Old Jan 10, 2003 | 07:39 PM
ford_nut's Avatar
ford_nut
Buck
I am happy with the trailer for sure. However, after I purchased it, I heard some people say that the spring under isnt as beefy as a spring over. I thought that I made out on the deal but nothing is more disheartening than to hear someone criticize yr choice. When I bought it, I was looking for load carrying capacity since Im going to be hauling frequent full loads of firewood. The dealer told me that a 6x12 tandem with a 7000 lb rating will be more than enough...then I heard the 'opinions'! Ever buy something new and then have someone close to you tell you 'I heard several bad things about that..' So my question to you is, how would that make YOU feel? Not pretty good Im sure...
regards
Ben
Old Jan 10, 2003 | 08:29 PM
PSD_Power's Avatar
PSD_Power
Several years ago I built a 16' tandem trailer in high school. A lot of people critisized everything I chose to do on it. But I built it how I wanted it and how I thought it would work. Now six years later those people that critisized how I built it are calling me up to help them haul cars and stuff. I just smile and say sure, no problem. I get a sence of satisfaction out of knowing that they still don't have a trailer as good as the one I built. I value my freinds opinions alot but you just have to take it with a grain of salt.
ohh yea, mine is a spring under 12,000 pound capacity. and it will haul it to.
Justin
https://www.ford-trucks.com/user_gallery/displaythumbnail.php?&photoid=9313&.jpg
http://members.lycos.nl/dukesofhazzard/dukeslogo.JPG
2002 F-350 SC LB 4X4 6SPD PSD. 3.73 gears. 2.5" leviling kit. K&N air filter. Rhino lined Bed. Prodigy trailer brake controler. 35x12.5x16.5 BFG A/T. 16.5x10 ultra wheels. pop up gooseneck hitch and firestone airbag spring helpers. Reese fifth wheel hitch for my new toy hauler. Superchips microtuner.
As of 1/05/03 Single and looking Any single females around?? (hey I gotta do what I gotta do)
Old Jan 13, 2003 | 02:32 PM
johnsdiesel
[updated:LAST EDITED ON 01-13-03 AT 03:34 PM (EST)]The spring under is very common in trailers and is a good design. I wouldn't change it unless you have a problem with the height of the trailer. The most important thing is to be able to tow level. Why waste money on changing the springs for no reason.
crash1
17
Apr 21, 2012 07:25 AM
muscletruck7379
May 15, 2004 11:51 PM
winfordr
Aug 18, 2002 12:48 PM
iknowitall
All Things Towing
May 18, 2001 10:09 AM
Superdave
18
Dec 11, 1999 10:34 PM
