Sponsored by: Auxito
Alternator help
Old Mar 30, 2009 | 09:15 PM
ronxp2000's Avatar
ronxp2000
Thanks
Thanks for the confirmation, I am glad to know it has a light too.
Thanks. I'll even check it out.
Good deal.
Originally Posted by KingRanchMan02
Your truck has a battery light and a battery guage. When you turn the ignition switch on the system does a check of the electrical system and computer with all of the lights in the dash being illuminated. Make sure that the battery symbol light comes on at this time. If it does not, the light in the dash needs to be replaced and is why you haven't seen a light come on. This light should come on if the battery is not charging properly.
The battery guage is not a true voltmeter but more a glorified idiot light. It indicates only that the voltage is in a normal range of 13.5 - 15 volts when the engine is running. When the voltage is in this range, the guage will indictate right in the middle of the range and will not vary at all even if the level is changing.
With the engine off the voltage should be 12 volts and with the engine off but ignition on it should still be 12 volts. Good luck!
hoppymerlin
Sep 3, 2020 11:21 AM
72camperspecial
May 28, 2013 09:12 PM
charlene3369
15
Dec 11, 2012 01:22 PM
Stoneguy
Apr 25, 2012 03:50 PM
dpm1057
May 8, 2007 07:19 PM
