Sponsored by: Auxito
2002 4X4 MOD5 removal
Old Mar 30, 2009 | 05:29 PM
agingF150guy's Avatar
agingF150guy
I'm trying to get the transmission out of an 2002 F150 4x4 for a clutch job. Right now, it doesn't seem like there is any easy solution to getting the top of the shifter tower to clear the floor pan. I've put a little pressure on engine block in front of the mounts to angle the drive line downwards, but it won't buy enough room to clear the floor and let the trans slide out. Anyone out there done this job?<o>></o>>
Old Mar 30, 2009 | 06:27 PM
fordfaninIL.'s Avatar
fordfaninIL.
I have not done this specific year, but usually if the stick and the stub shaft are removed from the top of the tranny then there is enough room to get it out.
Old Mar 31, 2009 | 06:02 AM
agingF150guy
2002 MOD5 4x4 removal
Upper and lower shift levels have been removed. It's the upper case casting (that houses the lower shift lever stub) that won't clear.
Old Mar 31, 2009 | 06:45 AM
fordfaninIL.
If you have not done so, try loosening the exhaust at the back of the manifold. There should be two bolts holding each flange. This should allow the engine to tip more.
